exterior paint for foamie
Postby rustytoolss » Thu Jun 08, 2017 8:33 pm
Within a few (or more ) weeks I should be able to paint my foamie. Got a few questions. 1 do you guys paint the body before installing thing like windows/vents etc, so that there is paint under the window flange surfaces ? 2 has anyone used the type of paint used to stop water from seeping through concrete block basement walls ? did not know if that may be something of any value ?
Mostly Old Parts And Rust= MOPAR
rustytoolss
Re: exterior paint for foamie
Postby GPW » Fri Jun 09, 2017 5:15 am
Rusty , Yes , paint first , then windows … ( all about protecting the fabric ... ;) )
We’ve used concrete block Fill … a Thicker primer …
What do you guys use on basement walls ? ( we don’t really have basements here , water table too high )
Postby Don L. » Fri Jun 09, 2017 6:10 am
Hi, I did 2 coats of gripper primer , then installed the windows and all and then did the final coats of paint after that.
I think my reasoning was because I used (adhesive) caulk behind the window/door flanges there was some squeeze out and that got wiped off with my finger, leaving a bit on the primer. Even though it was clear I wanted paint over it so it wouldn't look different over time. Often caulk will hold dirt or mildew and standout against a nice paint job.
Link to my foamie camper build viewtopic.php?f=55&t=67321
instagram #don_leister_violin.rva
Don L.
Postby rustytoolss » Fri Jun 09, 2017 9:36 am
GPW wrote:Rusty , Yes , paint first , then windows … ( all about protecting the fabric ... ;) )
Did you leave the concrete block fill paint "as" your final exterior body paint surface ?
rustytoolss
Postby GPW » Fri Jun 09, 2017 3:02 pm
er , No … It’s a primer … not an exterior coat … and we used ours on Blocks …
Postby rustytoolss » Tue Jun 13, 2017 7:06 pm
Has anyone used those newer paints with primer (all in one) paints ? Never tried it yet myself. :thinking:
rustytoolss
Postby GPW » Wed Jun 14, 2017 4:52 am
Rusty, our latest paint for the FoamStream says it’s a primer too …. Waiting for a dry spell to try it out … ( rainy season now )
Postby rustytoolss » Wed Jun 14, 2017 6:57 pm
This will be my Foamie's first body paint to cover the canvas/TBII. So I want to make sure to do it the correct way. 8) :thumbsup: :applause: :beer:
rustytoolss
Postby GPW » Thu Jun 15, 2017 5:16 am
Its really not too critical , sorta’ like painting the house …. same procedures … apply the paint to a clean dry surface ( canvas ) and use Good paint ( read the instructions on the can) ... :thumbsup:
