The "Grave Digger" Build Northeast Wisconsin
Postby Garrick » Tue Jun 13, 2017 9:57 am
My name is Garrick and I'm located in NE WI. This is my first build. I know it looks familiar as it is based off another and I am okay with that; it's a very functional design. I found the name "Grave Digger" appropriate as this will get used for all of my out of state hunts. I do not have a lot of woodworking or construction experience so I will be looking for some help from this community!
A few notes:
Trailer Frame:
- 2x2x.120 and 3x2x3/16 for main tube, 2x2x1/8 angle for stabilizers
- Torsion axle was bartered for on craigslist. Had to extend it 2" because I wrote down the wrong measurement for the frame...
- Going to use epoxy primer and eastwood extreme chassis paint.
Wheels:
- I have a perfect set of 3 with tires mounted and balanced but wont work with my axle unless I use some 1-1.5" spacers. Looking into this currently...
Body:
- Overall dimensions are approx. 60"x96"
- Skeletonized plywood walls
- Will be primed and coated with red bed liner or Durbak
Electrical:
- AC and DC. I will need help with this. I have a picture attached of a rough plan, will this work? I see a lot of people using converters/inverters and I don't see why I would in this setup...
trailer progress
Trailer progress.JPG (75.32 KiB) Viewed 684 times
rough sketch
Capture CAD1.JPG (24.01 KiB) Viewed 684 times
rough sketch
Capture CAD.JPG (32.62 KiB) Viewed 684 times
Garrick
Re: The Grave Digger Build Northeast Wisconsin
Postby Garrick » Tue Jun 13, 2017 9:58 am
1st draft...
Electric 1st draft.JPG (43.62 KiB) Viewed 681 times
Garrick
