Progressive Dynamics PD4045 install
Anything electric, AC or DC
Re: Progressive Dynamics PD4045 install
Postby noseoil » Wed Feb 10, 2016 11:18 pm
Here's what we have.
137905
noseoil
Images: 669
Postby blentz » Thu Feb 11, 2016 6:25 pm
Thanks, you just finished up some design issues I was having. I'm thinking my galley will look a lot like this.
blentz
Postby David Olson » Tue May 31, 2016 5:04 pm
Thanks for all the great info in this thread.
I flipped the switch today on my PD4135 and bingo all is good.
Camp Inn 560 Raindrop #541
Out Back 13'
"Count Your Blessings Not Your Troubles"
David Olson
Postby pirijodonny » Wed Jun 01, 2016 7:16 am
This thread has helped me a ton! Thank you! I am just about done wiring my AC and DC lines in my Cargo Trailer conversion and ready to connect them to the PD4045. I have taken the walls down and want to make sure I have everything wired right and it works before I insulate and put the walls up. What have you all been doing to test? I don't have a 30 amp source, only 15 amp to plug into at home. I don't want to move it before I put the walls back up (just paranoia on my part). I have a 30 amp to 15 amp adapter. I was going to plug in and just test one circuit at a time. What do you experts say?
Thanks again.
pirijodonny
Images: 29
Postby noseoil » Wed Jun 01, 2016 7:25 am
That's really the best way to do it. Check each circuit individually. You don't need 30 amps (we use 15 only & we're fine with what we have) available for just the testing part. If each branch is good, then you did it right & it works.
I did the same thing for the 12 volt stuff. A small alarm panel battery (1.3 amp hours) with 2 alligator clips is my "test equipment" for each circuit. If it works, just hook it to the panel.
It's still just one at a time stuff for electrical. I wouldn't want to wire everything up to see if it works when it's done!
137905
noseoil
Images: 669
Postby antalog » Sun Sep 11, 2016 7:30 pm
Yeah, this was an amazing thread. Thanks to everyone who posted helpful info in it! It looks like H.A. opted to remove some of his info. Bummer cause every bit helps I reckon, but I understand (Ive read some of the electricity 'conflicts' here :? )
Either way, thank you for this!
...Sticky?
antalog
Postby Mel's Way » Wed Mar 22, 2017 9:51 am
Why install the black pos. from the inverter to the non-supplied bus bar? As shown in the colored diagram. Why not directly to the 15 amp. breaker? (Red circle shows the non-supplied bus bar.) Is the bus bar needed for other necessary applications? I will also supply a photo of my actual new product still in the box showing there is no bus bar installed. Thank you for clarification; I don't want to do this incorrectly. MEL
Mel's Way
Postby absolutsnwbrdr » Wed Mar 22, 2017 3:34 pm
That's interesting that they no longer supply a hot bus bar. At the time I made the wiring diagram, the black, white, and green wires to the converter were already terminated at their respective bus bars, so I just made a short jumper wire from that hot bus bar to the breaker.
Since it appears Progressive Dynamics is cutting back and trying to save $0.31 cents per unit and no longer supplying the hot buss bar, your black wire from your converter will go directly to the breaker, as you described. This will be good information if other people discover the same scenario.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby Boreal » Thu Jun 22, 2017 9:16 pm
absolutsnwbrdr wrote:All of your 12V accessories & lights then get their negative wires tied to the ground bar.
Where is the DC ground bar? I see the AC gound bar, but where is the ground for DC?
Boreal
Images: 19
Postby GuitarPhotog » Fri Jun 23, 2017 12:56 am
You need to provide it.
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby absolutsnwbrdr » Fri Jun 23, 2017 10:57 am
<Chas>
:beer:
Yup. I have this one... https://www.amazon.com/Common-Ground-Br ... 06X9ZGY2W/
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby Boreal » Fri Jun 23, 2017 9:46 pm
absolutsnwbrdr wrote:Yup. I have this one... https://www.amazon.com/Common-Ground-Br ... 06X9ZGY2W/
Plastic base. So I'll screw it onto a wood bulkhead, run my white wires of my DC circuits to it, and also run a line back from my PD unit, from the Black negative to the bus.
Question: Is it absolutely necessary to lay out a line from negative battery/Black to my metal trailer frame?
Boreal
Images: 19
Return to Electrical Secrets
