I had a piece of scrap oak plank laying around so I installed a piece at the threshold of the RV door where the foot traffic and scraping takes place as I drag stuff in and out of the trailer.
- 170801 Floor Threshold (480x640).jpg (180.4 KiB) Viewed 4230 times
I have not yet insulated the floor in the rear on the side where my quick release Condor chock is located because I need to raise the chock before I lay down 1” of foam plus 3/4” of plywood. Otherwise, the rear of the 900lb. motorcycle will stick up 1 3/4” higher than the chock, making it very difficult to wrestle the bike backwards out of the chock, even with the nose of the trailer jacked up.
- 170801 Floor Plywood 3 (480x640).jpg (175.98 KiB) Viewed 4230 times
The plywood is easily removable. In due course, I will attach a small, low profile cleat between each sheet of plywood at the seam to prevent the plywood from creeping to the rear of the trailer.
As need arises, I will cut out small, rectangular openings through the plywood floor to access the E-track with clips. You can see one cutout on the right side of the chock leg I made to accommodate the width of the chock.
