Wise and prudent thinking Don.
McDave
low277 wrote:Lots of books, documents and papers written on grounding and bonding. Everything from Uffer's concrete encased electrodes, to Sourses book on grounding to the NEC article 250.
It's called AC theory for a reason!!!!!
flboy wrote:low277 wrote:Lots of books, documents and papers written on grounding and bonding. Everything from Uffer's concrete encased electrodes, to Sourses book on grounding to the NEC article 250.
Yes, all that gets rather technical very quickly. Aside from the normal AC and DC electrical system grounding considerations.. I have to consider RF grounding as well since I'll be operating HF and VHF (QRP and QRO) gear on the 12VDC system in my CTC from time to time..... but that is more a topic for a radio forum. :-)
It is a Theory, but very demonstrable. People are shocked to find that out!
Lol... Did have some bacon hiding in there somewhere. We did alot of cooking this time. Mostly breakfast and dinner. Typically picked up lunch while out riding or etc..McDave wrote:What is all that stuff? No bacon? No Jameson? Not even a beer? Yikes! I guess your cigars must be in the wife's purse? I'm a little worried, Don. But I do dig those Georgia peaches.
McDave
jr9744 wrote:One thing I've started doing is gathering all the wood in the house of stuff I can 'repurpose'. I'm also starting to think more about design and how I really want the final look and feel to be.
Some things that still keep me up at night though (In case anyone can give feedback):
* Is it really that bad to cut a stud for a window? I fear I may need to do this but worry about the integrity of the structure if I do so.
* I'm growing really interested in using pine tongue and groove for the walls and roof. I worry about the weight with all pine. I need to go to a weight station or do the math.
* Where would be the cheapest place to have someone put back on my trailer door ramp coil spring and lines? Long story, but I took it off and have really struggled putting it back on. Ready to pay someone to help if I need too.
Yes would be heavy.jr9744 wrote: pine tongue and groove for the walls and roof. I worry about the weight with all pine.
John61CT wrote:Yes would be heavy.jr9744 wrote: pine tongue and groove for the walls and roof. I worry about the weight with all pine.
Has anyone ripped luan or other thin sheets to make faux paneling?
Obviously would be too thin for proper shiplap rabbeting, just plain lap joins. Maybe somewhat fragile, but cheap and easy to fix
A nice quality sheet to start with would probably give a very nice "land yacht" effect with tung oil, or if you want to avoid it darkening, Epifanes "Rubbed Effect".
Just aesthetically, I would just do the above on the walls.
Wood all around would IMO make the space seem smaller, maybe get oppressive. But wood panelling and a plain white ceiling, maybe flat textured, think that would be nice with an attractive warm-temp lighting scheme
McDave wrote:jr9744 wrote:
Hey jr9744,
You have made some significant progress there. The "infrastructure stage" is a time consuming and sometimes less than rewarding process, but ya just gotta go through it. The time spent in planning and building at this stage helps to prevent rework and future regret. You are real close to the "fun" part. When the finishes start coming in and stuff is visually rewarding the work is a lot more satisfying.
It is not bad to cut a stud for a window, as long as you finish that job. Just like normal construction, you need to install a header and sill plate. The header distributes the roof load to the adjacent studs and the sill plate carries the window load. This also keeps the wall and roof framing straight, level and plumb. The window then has a sturdy frame around it. It is not a tough job really. It doesn't have to be welded in if you're not able, but you do need to have a mechanical connection between the header or sill plate and the cut stud and the adjacent studs. Screwed or riveted works fine.
I have seen the tongue and groove pine and cedar planking for walls and ceilings that is 1/4"x4"x8' but I haven't found a weight on them. 1/4" should be fairly light, but it all adds up.
If the ramp spring and cable are still intact I may be able to help coach you through install. Do you want to post a pic. or two and describe the problem?
I love the idea of repurposing old stuff. It gives a really unique look that cant be duplicated. And all that stuff you have been hoarding has a new life. That's the fun part.
McDave
