fourbtgait wrote:Plumbing all installed, no leaks. Wife is happy. Just need to run propane to the eater heater.
I did some tongue weight playing. I want a minimum of 300 pound tongue weight. Set up with full water tank, water heater full, weight of rear ice chest, food, then clothes in front (all using free weights from our basement gym), I will need the weight of the spare, battery and propane tank on the hitch. We typically also tale a 45 qt ice chest only for drinks/water, so that will ride in very front compartment. Puts me at 315 tongue weight.
Tomorrow I will pull one of the tires/hubs to get the bearing numbers, then from Etrailer order brakes and hubs. 3,000 pounds of trailer is 60% ov TV capacity and its own weight, so needs breaks for the mountains.
McDave wrote:I think that will be my next upgrade as well. My tow vehicle is a 3/4 ton GMC conversion van and it works well and stops pretty good . But things can get sketchy pretty fast when that 1 1/2 ton trailer is chasing you and trying to push you around in a panic stop. I'll be watching to see how it's done. Seems like I priced it out at about 500-600?
McDave
hankaye wrote:fourbtgait, Howdy
When you go to order the brakes etc. don't forget that you'll also be needing a seven-way plug connection
and the wiring for both the trailer and tow vehicle unless the tv already has one. Easier to only pay for shipping once.
hank
Users browsing this forum: Bing [Bot] and 17 guests
