GPW wrote:“ and my pressure treated wood “ …
amandacreiglow wrote:On the doors, I've opted to go with the 80/20 aluminum framing. I was starting to get the frames into a shape that would technically work, eventually, but would be uneven enough that it would always bother me. I just have more confidence that I'm going to end up with something that looks not noticeably uneven with the aluminum. All KC's concerns are certainly valid, but in this situation, for me, it's the lesser of two evils,. Plus, with the design i'm going with, and the fact that it'll be all wrapped up with foam and canvas, they should mostly be mitigated. The only metal from the outside that reaches the inside will be the door handle, which would be the case with the handles I went with regardless of what I built the frame out of.
amandacreiglow wrote:Trying to decide if I should try to spackle to even it out before I get my final paint on there. My concern is that it'll be a different texture than the rest of the wall (smoother, rather than the slightly rough fabric texture that I quite like), and I'll have done the extra work for only marginal improvement.
ghcoe wrote:
I guess I misread what was being discussed earlier. I 2"x1" flashing for my door edges. I also used pop rivets to attach hinges and hardware.
John61CT wrote:Are you using the 80/20 profiles for interior fittings only or actually framing your outer shell?
Anyone know how it compares to MiniTec?
John61CT wrote:I was thinking a walls+roof box that can break down to pieces, made of profiles+foamie that supports a heavy roofrack load, sits on a flatbed trailer for travel, or can site on a raised deck or slab on the ground.
