Qool Stream. First time builder
Up-cycled insulation fitted
Postby Mudpuppy » Mon Sep 25, 2017 1:15 am
151237151236151235151234151233
foam and polystyrene all up-cycled from old packaging from work
Mudpuppy
Images: 197
Pop up roof update
Postby Mudpuppy » Mon Sep 25, 2017 1:16 am
151238151239151240151241151242151243151244151245151246
I was originally going to have the roof go straight up but the hinged method seems to suit it better
I up-cycled the tarpaulin which covered the Trailer whilst under construction
this will be a temporary thing until i find some thing i like better
Mudpuppy
Images: 197
Black and White Flooring fitted
Postby Mudpuppy » Mon Sep 25, 2017 1:17 am
151248151247
Mudpuppy
Images: 197
Pretty things being fitted
Postby Mudpuppy » Mon Sep 25, 2017 1:22 am
151249151250151252151253151254151255
The lights are from a land rover to make things look older
the number plate cover is a up-cycled one from an old VW beetle
the fog light is from a new mini but it had a slight curve in it so I made a small frame and hot glued it together
I have been using poly urethane adhesive so I fitted it filled the gap and will put the rivets in when it sets
Mudpuppy
Images: 197
Re: Qool Stream. First time builder
Postby ST1100 » Mon Sep 25, 2017 3:37 am
Maybe I can visit you, when I come to GB with my tiny Airstream. Possibly in 2018 !
If you visit Southern Germany, you are welcome here in Passau with your Beetle and trailer :)
50 years camper and 35 years biker !
1977 Eriba Troll
2001 Honda GL1800 with trailer hitch, Ford Focus Pininfarina Convertible with hitch
ST1100
Images: 199
Postby Mudpuppy » Mon Sep 25, 2017 12:25 pm
ST1100 wrote:Maybe I can visit you, when I come to GB with my tiny Airstream. Possibly in 2018 !
Hi I love the area you live in
I lived in leonburg near Stuttgart for a couple of years
In the little village with the Porsche test track in weissach
Mudpuppy
Images: 197
Postby S. Heisley » Mon Sep 25, 2017 8:58 pm
I just added your build into "Teardrops and Tiny Travel Trailers with lifting roofs":
viewtopic.php?f=5&t=50969
I don't know how I missed this build and here you are, almost done! Beautiful job, too! :thumbsup: :thumbsup:
Postby ST1100 » Tue Sep 26, 2017 3:28 am
Mudpuppy wrote:Hi I love the area you live in
You are welcome to come again :)
1977 Eriba Troll
ST1100
Images: 199
Postby Mudpuppy » Thu Oct 05, 2017 1:49 pm
S. Heisley wrote:I just added your build into "Teardrops and Tiny Travel Trailers with lifting roofs":
Thank you for the kind words :beer:
The tarp section should be temporary item as the internal come next i wanted to be able to stand up and work inside in the rain
I am looking into getting it made from up-cycled sail material
Have a look at "Cornwall bag company" on facebook or twitter they make some lovely bags and things from sail off-cuts
I was hoping to be able to lay in the Qool Stream and see the stars
:D
Mudpuppy
Images: 197
Re: Qool Stream top corners tiny travel trailer
Postby conn.rod » Sun Jul 25, 2021 5:21 am
Mudpuppy wrote:150330150331150332
My first attempt at going around corners without curving the metal in both directions
150333150334
"second attempt make smaller fish sections for the BEN HUR shoulder pad look
aren't you afraid the pop rivets will leak? I know this is an old thread but asking questions
conn.rod
