phoenixbound wrote:I see a lot of folks using 2 x 2 's for framing for counters and cabinets. Great idea, I like it. Just wondering about joints. It looks like everyone uses simple butt joints, but I am sure there is more to it than that. I would worry about the 2 x 2 splitting if I ran a screw in it. All help and especially pictures are appreciated.
CoventryKid wrote:
Phoenixbound:
Hope the above pictures helps...when I secured the horizontal 2x2s to the vertical 2x2s, I simply drilled thru the vertical 2x2 into the horizontal one - no predrilling. However, at the other end where I had to toenail the horizontal 2x2 to the vertical one, I predrilled so I wouldn't split the wood.
So I hope I'm not simplifying it too much, but at a T joint, I did not predrill; at a toenail joint, I did.
After 2+ years and 30 some odd thousand miles (not kms), no failures.
As far as cabinets are concerned, I used 1/2 plywood and simple butt joints (never seen, so no esthetic value in doing anything fancier).
Hope this helps.
