Iconfabul8 wrote:Welcome to the forum
The boost charge only charges to 90%. If you read the next line down the Normal Mode "Safely completes the charge"
https://www.progressivedyn.com/rv/power ... 00-series/
hankaye wrote:smtxom, Howdy;
Welcome to the forum, the information you seek is in the link already provided.
Open it and look for the DOWNLOADS tab, give it a click and you will find the
one for installation and a few others things as well.
hank
Mark959 wrote:so the mighty mini is a distribution panel and charges the batteries, and is a power converter?
is this for you guys that plug into shore power to charge batteries (while also using solar?) while providing 120v to the trailer or what?
Or do you provide the inverter for 120vac from 12vdc, use this as a breaker box, and also provide a solar controller to charge batteries off grid, use this ongrid to charge batteries?
mppt solar charging is very efficient
