Very interesting little generator
Re: Very interesting little generator
Postby John61CT » Sun Dec 17, 2017 11:02 am
I was just addressing this concern which was in response to my claification that propane can be stored for centuries NP.
NotJammer wrote:Propane tanks don't last forever. They rust or corrode. By Law need inspection periodically.
I believe new DOT-type metal bottles are 15 years from mfg date, then need re-cert inspection every ten years.
Stamped right on the collar. True even for aluminum, which of course don't rust.
I doubt you'd actually have much trouble with the Viking tanks in practice, quiet confident manner expecting success.
Worst case carry the DOT cert docs, maybe a notarized letter from the US distributor put impressive official looking stamps on it.
Nice bonus thing is, they're transparent, see the level at a glance.
John61CT
Postby NotJammer » Sun Dec 17, 2017 11:35 am
John,
Aluminum can corrode and does.
NotJammer
Postby Pinstriper » Tue Feb 27, 2018 6:15 pm
Just a bump on this, I went camping for four days at 4500’ altitude, temps down to -2 F. I took the Sportsman instead of the Ryobi propane.
Started and ran fine, did a good job, but at 800W, it couldn’t keep up with the startup surge on my 500W electric heater. The 350W heater was fine but itself couldn’t keep up with the low temps. I was getting 5+ hours on a not-quite full tank. I ended up resorting to a heater buddy for heat, running it for 20 min. every hour or so. The Sportsman worked great but just not big enough to provide electric heat in those temps.
Let's eat, Grandma !
Let's eat Grandma !
Commas. They save lives.
Pinstriper
Postby booyah » Thu Mar 01, 2018 9:40 pm
Would have liked to hear how the ryobi ran in those conditions.
Ah well. I know boiling point for propane is -42F, so below zero shoudnt be a problem as long as its not WAY below zero
My build, 5x8 modified benroy "Smiles to go". Started April 2nd 2015, first trip August 2nd 2015.
viewtopic.php?f=50&t=63145
booyah
Postby Pinstriper » Sat Mar 03, 2018 11:03 pm
booyah wrote:Would have liked to hear how the ryobi ran in those conditions.
Yeah, I wasn’t prepared to risk it, but I guess I should brought both along. Next time.
Let's eat Grandma !
Pinstriper
Postby Pinstriper » Mon Mar 05, 2018 9:43 am
Let's eat Grandma !
Pinstriper
Postby booyah » Thu Mar 08, 2018 3:00 pm
Love the little wen, I have that guy for home use
booyah
