Little Spark
Little Spark
Postby ojgrsoi » Mon Dec 18, 2017 9:05 pm
I am building a small camper. I have been working on it since June. It started out great but life got in the way with a death in the family, vacation, and working in hurricane recovery. I hope to get started back on the work after Christmas. I purchased a frame off CL. Painted and rewired it as well as installing an axle. Then I built the base with under floor storage. It will have solar charger for the 12V system as well as 110 for AC. I have a 3 speed speed fan for the roof.
Here is the progress.
Trailer floor is 5x8.
Here you might be able to see the floor will be about 10 inches wider than the trailer floor. This gives more room for a queen size matress. Also raising the floor above the fenders allowed for under floor storage. There will be LED lights in the under floor storage.
Here is video 1.
https://youtu.be/2WP-nA5XnS0
Here is video 2.
https://youtu.be/BK9fohwgU3g
Mark
Weatherford - True Texas
https://youtu.be/BKs6XfgAKKc
ojgrsoi
Re: Little Spark
Postby ojgrsoi » Mon Dec 18, 2017 9:13 pm
Here is video 3.
https://youtu.be/n5sbyRmaBdk
Here is video 4.
https://youtu.be/cFX5o1xbAi0
Hope to work on this and post more soon.
Mark
ojgrsoi
Re: Little Spark
Postby greygoos » Tue Dec 19, 2017 9:05 am
Nice Work. Good luck with your build
greygoos
Re: Little Spark
Postby swoody126 » Tue Dec 19, 2017 9:10 am
LOTSA thought and planning in evidence
love the recycled materials :thumbsup:
sw
swoody126
Re: Little Spark
Postby ojgrsoi » Tue Dec 19, 2017 8:58 pm
swoody126 wrote:LOTSA thought and planning in evidence
I've been reading tnttt for almost two years. No original ideas from me. Credit goes to youse guys. :miriams:
Mark
ojgrsoi
Re: Little Spark
Postby ojgrsoi » Tue Dec 19, 2017 9:00 pm
greygoos wrote:Nice Work. Good luck with your build
Thanks.
Mark
ojgrsoi
Re: Little Spark
Postby Woodbutcher » Wed Dec 20, 2017 8:45 am
Well done! :applause: You should be on the road to adventure very soon.
Woodbutcher
Re: Little Spark
Postby pchast » Wed Dec 20, 2017 9:24 pm
I'm intrigued by th e little jeep in your signature :thinking: ......
Is that a commercial unit or homemade?
pchast
Images: 97
Re: Little Spark
Postby ojgrsoi » Thu Dec 21, 2017 8:48 am
pchast wrote:I'm intrigued by th e little jeep in your signature :thinking: ......
It's a Barbie jeep painted camo. I bought if off CL for $20. My grandkids ran the wheels off the thing. I found that original owners buy those electrics and get tired of falling over them in the garage when the first battery dies. The child has outgrown it and then they just want it out of the way. You can buy a small server battery (12SLA) pretty cheap and change the connectors to make a very inexpensive toy. Kids don't care if its used. They just like to ride it. At one time I had four. Then my grandkids outgrew them and I gave them away.
Mark
ojgrsoi
Re: Little Spark
Postby ojgrsoi » Tue Mar 27, 2018 6:03 pm
Had a setback. Big rain got the ceiling wet and slightly warped the street side. I installed an angle brace on the outside. It has holes in it. I drilled holes and pulled it straight using lag screws and a 2x4 on the inside near the center. It is now straight.
I have removed and trashed the water damaged ceiling. Had to unwire the 110 where it was drilled through a ceiling panel. Also today I'm installing the side marker lights as I am moving.
I know this is where I should post photos. Not much to see. :(
Mark
ojgrsoi
Re: Little Spark
Postby Staryder61 » Wed Apr 04, 2018 11:40 am
Sorry to hear about the rain damage,, :( though, you are recovering.. :) Have had a few days of "Two steps forward, one step back"
The build looks great so far :thumbsup: :thumbsup:
Keep going, you'll be enjoying before long..
Stay safe, David
Our CTC
6' X 12' CTC = Texas Sized Tackle Box
Staryder61
Images: 528
Re: Little Spark
Postby ojgrsoi » Thu Apr 05, 2018 9:12 pm
Installed the hold my junk shelf and wired in the LED lights.
Mark
ojgrsoi
Re: Little Spark
Postby ojgrsoi » Tue Apr 17, 2018 9:56 pm
Finished a little more. Wiring and ceiling is done. Ready to move and get titled soon.
There are three 12V circuits. One feeds the cabin 12V panel with a lighter socket, USB socket, voltage gauge and switched wall lights. The next circuit is for the fan and overhead light. The third feeds the galley lights, 12V lighter/USB sockets and another voltage gauge. The two 120V breakers feed 1) the three wall outlets and 2) the battery charger. All outlets are on gfci.
Mark
ojgrsoi
Re: Little Spark
Postby ojgrsoi » Tue Apr 17, 2018 10:18 pm
Also added the shore line plug. I have a fantastic fan which I'll install when I finish the outside.
Mark
ojgrsoi
Re: Little Spark
Postby ojgrsoi » Wed Apr 18, 2018 7:11 pm
Put the door on and bent some plywood today. Fan mounted but not connected. Trying to get this so it will move down the road.
The door is from an AMGeneral DJ5M. The rear door opening is the same size. I'm shopping CL for another door.
Mark
ojgrsoi
Users browsing this forum: Wynsome and 13 guests
