To paint or not.
To paint or not.
Postby bete » Mon Jan 08, 2018 1:35 pm
My cargo has a white roof from the factory. Would I still benefit from painting on the rv roof coating? Thank you.
bete
Re: To paint or not.
Postby hankaye » Mon Jan 08, 2018 6:04 pm
bete, Howdy;
Welcome to the site! Good to see you are putting us in your helper bucket right off. :thumbsup: , :thumbsup: .
Ask the manufacturer what they used to paint it with or if it is a coating form the mill where
the roofing material was made. Either way, you'll find out if it helps keep the heat out when
it turns warmer outside.
hank
hankaye
Postby McDave » Tue Jan 09, 2018 8:18 am
McDave
Images: 412
Postby Mark959 » Tue Jan 09, 2018 9:00 pm
Paint, IMO.
These tin roofs conduct heat a lot, any resistance and reflectance will help
Mark959
Postby hankaye » Tue Jan 09, 2018 10:41 pm
bete, Howdy;
I'd also paint but bear in mind that you'll need to prep the current surface.
By that I mean scuff sand it, clean off all the dust and clean completely with
acetone, mineral spirits or something compatible with the coating recommended
by McDave.
hank
hankaye
Postby bete » Wed Jan 10, 2018 8:03 pm
Thanks guys, guess I will be painting.
bete
