Wall Attachment Advice/Input
Postby JackieK » Wed Jan 31, 2018 2:53 pm
So I need a little advice on attaching my walls to frame. First of all my frame is made from angle iron 3"x4" and I really didn't see any info on the forum for attaching walls to this kind of frame. After thinking about it for a while I came up with this...
wall section.jpg (19.33 KiB) Viewed 1517 times
Hopefully you can get the idea from this simple diagram...
Just wanted to get a second opinion or see if there was any concerns I was overlooking...
JackieK
Re: Wall Attachment Advice/Input
Postby Woodbutcher » Wed Jan 31, 2018 7:28 pm
What you are planning will work, but it will be heavy. You don't say what your sides will be, just wood or skinned with aluminum, or something else. I built my first TD like you. It was heavy. My second TD has only a 1/2" floor and no insulation in the floor or walls. I do have several metal cross supports in the frame to support the wood floor. This cut the weight way down. If you don't camp in real cold weather I don't think insulation, especially in the floor is needed. Others will differ.
Woodbutcher
Postby edgeau » Wed Jan 31, 2018 9:22 pm
On the outside of your carriage bolts use nice wide washers and put some sealant all around the side of the washer that contacts the wood.
Sent from my Pixel using Tapatalk
edgeau
Postby baileydog13 » Fri Apr 20, 2018 9:08 am
Woodbutcher wrote:My second TD has only a 1/2" floor and no insulation in the floor or walls.
Woodbutcher..have you had an interior condensation issues with your 2nd build?
fishin' ain't always catchin'
baileydog13
Users browsing this forum: Google [Bot] and 7 guests
