ris wrote:Sorry to here you messed up your wires. I kept checking my trailer lights as I was doing the trim as I feared I would put a nail or screw through one of the trailer lights. They used about 3 colors of wire on our trailer. We replaced all the clamp wire connectors with butt joint connectors that had shrink wrap ends with glue in the shrink wrap of the connectors. We also replaced some of the wires. For some reason they ran a wire from the driver side front, top light all the way to the driver side rear light at the top. We removed this 16 ft. of wire and from the rear back light, ran a 10 inch wire to this same light. Hope you figure a way to fix without messing up too much of your trim.
Richard
phoenixbound wrote:Trying to track down an issue with my taillights and clearance lights and it got me wondering if there is a standard wiring for manufactured trailers. I mean the wiring colors. It would help a lot if I knew which wire I need to be checking. In the process of trimming out the interior I have disrupted a wire somewhere and my taillights and clearance lights are not working. Thank you.
McDave wrote:Glad you tracked it down. Here is an information page on trailer wiring. It covers color codes and connectors as well as wire size. Also some troubleshooting basics. Could come in handy, print a copy and keep in the trailer.
https://www.etrailer.com/faq-wiring.aspx
Good Luck
McDave
Users browsing this forum: Google [Bot] and 5 guests
