lilgription wrote:Sorry if this is in the wrong section. I wasn’t sure where to ask this. What is the most common method for finishing plywood for the exterior if not skinning. Sealing + primer + epoxy paint ? Or ? Any help is appreciated
John61CT wrote:Glidden Gripper primer, thinned a bit for first few coats, really try to get full coverage, edges crannies much as possible, then at full strength, a couple more coats.
Then porch paint, color of your choice after that.
Or something glossy high tech if you want
