Just finished cutting the replacements for the two ribs I screwed up yesterday. Glad I did it. They are way better and will fit much nicer to the hatch skin.
Here is the plan for the rest of the hatch. First off I'm using a Fredericks style side wall seal system. So the outer most hatch ribs are made of 3 parts.
1. Outer exterior rib
2. 3/4" wide by 1" tall inner seal spacer
3. Inner galley rib
Those 3 parts laminate together to make a deep U shaped channel to mount the weather strip in.
In the photo below is how I'm going to handle where the hatch meets the body/rear bulk head. I used a large oak beam across the tear body. I have a second matching beam that will be the leading edge of the hatch. The two beams will be spaced to allow my weather strip to compress between them when the hatch is closed. The plywood spacer shown between the beams gives me the right crush distance for my rubber weatherstrip.
- DSCF3692a.jpg (58.22 KiB) Viewed 3381 times
- DSCF3693a.jpg (53.11 KiB) Viewed 3381 times
The second photo shows my hinge and rubber seal strip. They are not in the right place. Just laid up there to get a pic.
The beams are as wide as they are because I have about a 3" wide piano hinge for the hatch. I wanted to screw that hinge into hardwood. I am going to seal the hinge with a continuous strip of rubber. I am leaning toward using the rubber under the hinge like a gasket. Down side is I'll be drilling a lot of screw holes through the rubber. Alternate would be to cover over the top of the hinge. Which now requires more metal strips to secure the lead and trailing edge of the rubber to the body. All my surfing on the site here says both methods have been used successfully. I do think the rubber under method would look nicer. I'm all about the look. So most likely I'll go that route.
As you can see in the top photo above the beam oak beam will touch the outer rib and get screwed and glued to it. You can also see the center weatherstrip spacer right next to the rib and touching the beam. The underside of the beam is undercut to match the thickness of the weatherstrip spacer. So my seal will have a continuous rail to glue to from rib to beam. The galley side inner rib is not shown in this picture. It will sandwich next to the seal spacer.
As far as mounting all the inner ribs to the beam I'm thinking I will make some deep dado cuts in the beam to position and mount the ribs to the beam. I will "l" notch the ribs to match the dado cuts so I get a smooth upper skin surface from the beam to rib mount/transition point.
The bottom edge of hatch ribs will have an oak face cap to attach too, across the full width of the trailer. The inside edge of the body will get a 90 degree aluminum L angle across the top edge and rear face of trailer body. The oak beam will be spaced away from the rear trailer face for weatherstrip crush distance. All the weatherstrip will be mounted to the hatch. Not the body.
I have 2 barn door spring lock bolts I am going to use to lock the hatch. These usually go at the tops of doors, have a chain and ring that hangs down. You pull on the ring and chain to release the bolt and open the door. I am going to use them horizontal and attach the ring and chains to an exterior locking garage door T handle.
I also plan several horizontal stiffeners between the vertical ribs. I'm very tempted to use some leftover cedar fence pickets to make them from. Very light weight and will glue an hold to the hatch well. I am also going to cut some aluminum plate I have to follow a good 8-10 inches of the hatch ribs. These plates will be screwed to the ribs to reinforce them for mounting my gas lift struts. The skin will be PL adhesive attached to the ribs and stapled with 1" staples. Going to frame and skin the hatch in place. then remove it. I will take out my rear galley cabinet before I build the hatch, so I can get to the galley from the cabin. Then I can unscrew the hatch from the body when it's built.
I was really debating the whole horizontal vs vertical ribs thing. To the point of "analysis paralysis". In other words not getting anything done. I truly did leave my rib direction choice to fate if I had the material on hand or not. As KC Studly pointed out there is a strong theoretical case to use vertical ribs. As dozens of builders up here have proven, horizontal works fine too. Multiple practical success stories on the board here for that way too. Truly a coin toss to me.
Next week I will have another 8 day stretch off from work. Hope to get at least 5 days of it out in the shop hammering away on this. I'll keep the progress pics coming. As always I welcome some alternate ideas or feedback to my hatch plan.
