dirtsailor2003 wrote:My friend installed the ARB 2500 awning on his van. He also purchased the tent walls that attach to it. Works great. The only thing that would be a slight issue is the wheel wells on the trailer would push the walls in a bit. I ordered the 2500 awning plan on putting it on the side of my 6x10. I may eventually get the walls too.
onehoser wrote:i've ordered the napier backroadz suv tent. i'll post up a critique when it arrives
John61CT wrote:Walmart CONNECTent
beachguy005 wrote:I've considered using one of these. Looks like the large door might accommodate fender and a side door of a CT. You'll also have a stand alone canopy.
https://www.ezup.com/camping-cube-straight-leg-6-4.html
hankaye wrote:rebar, Howdy;
If you think the Oz may be the ticket for you then contact the manufacturer
and see what they say to your questions. They may be able to build to your
needs or they may not. If you don't ask, you'll never know.
hank
dirtsailor2003 wrote:My friend that bought the ARB looked at the OZ also (in person at a Sportsman show). He chose the ARB because it is heavier duty material all around.
I ordered my ARB awning and will post photos of it in use when I get it installed this week.
domoarigato wrote:http://bearcreekcanvas.com/index.cfm
They did a great job, used better materials than used at the factory and even had a tinted window option (which he went with and looked great). They or somebody like them may be able to do this type of project. Ultimately if you wanted to do it up nice and clean, you would utilize the exact same anchor strip and channel that is used in tent trailers.
There are options out there, just gotta shake the bushes a bit and see what pops up.
-Domo
