Finally underway with our 7X14 V-nose conversion
Re: Finally underway with our 7X14 V-nose conversion
Postby wyldesyde007 » Sun Jun 24, 2018 6:03 am
rebar wrote:
wyldesyde007 wrote:
rebar wrote:Yeah, your really moving along. Looks great!
Well I'm under a little diress, my wife had already booked a campsite!! :R
BTW this all took place last week. I didn't have any free time to get the journal going with the deadline looming. Sheesh! I was working on this thing every night after work.
I hate dead lines. From what I see your not cutting any corners..
I'm doing my best not to rebar, my wife often says jokingly that I am the king of 99% I'll get a project almost complete and then move on to another.
wyldesyde007
Images: 131
Postby wyldesyde007 » Sun Jun 24, 2018 6:26 am
With the bedframes installed I moved on with getting the bathroom built. With the camping date fast approaching I figured it was more important than the kitchenette and by working my way along towards the back of the camper I could make adjustments to the subsequent components as I linked them, i.e. by the time I got done with the bathroom the future rear bench area shrank from 36 inches to 34.
155019
This first wall is 3/4" thick and attached to the bunks
154989
The last two walls were framed for the addition of plumbing at a later date.
154992154990
I installed the bathroom light before I skinned it so I would be able to see in there! It's an led surface mount.
154994154995
Skinned
154996
And the door installed
155007
I used a decorative screen door latch for the hardware and it locks too.
155005155006
End of day four
wyldesyde007
Images: 131
Postby wyldesyde007 » Sun Jun 24, 2018 6:34 am
I got a little out of order because I built the rear bulkhead wall before the bathroom :oops:
The concept
155021155020
Framing it up
154985154986154987154988
The slot at the top of the door is for an eventual duct to pass a/c out to the fold out room ;)
End of day three
wyldesyde007
Images: 131
Postby rebar » Sun Jun 24, 2018 7:21 am
Maybe its more that I like to procrastinate.. Or be 100% that I'm not making a mistake.
What kind of wood paneling is that?
97 12 valve 4x4 5 speed
rebar
Postby wyldesyde007 » Sun Jun 24, 2018 2:30 pm
I got the bathroom together quicker than expected so on to the kitchenette!
155018
All of the kitchen cabinets were installed as I built them on the night before we were to go camping! :shock:
154999155000
155001155002
155003
I ended up running out of time and forgot the drawer header and lower pantry door at work so those didn't get attached before we left.
The countertop is temporary until I can get the laminated one done.
wyldesyde007
Images: 131
Postby wyldesyde007 » Sun Jun 24, 2018 2:34 pm
rebar wrote:Maybe its more that I like to procrastinate.. Or be 100% that I'm not making a mistake.
I got it from Lowes, it's called "blonde wood" it came pre primed for painting and what you are seeing is the back side. We liked the look of the straight grain so I turned it backwards and clear coated it.
wyldesyde007
Images: 131
Postby wyldesyde007 » Sun Jun 24, 2018 2:56 pm
A couple of little details that I was able to knock out on the day we were to leave for the campground (and much needed).
Bought a cheap work platform from harbor freight and had to cut off 4" to get it to the right height.
155008155009
I used these command hooks for curtain rod brackets, so far they seem to be holding well :D
154997155016
wyldesyde007
Images: 131
Postby featherliteCT1 » Sun Jun 24, 2018 5:52 pm
Man you work fast! .... beautiful! :applause:
featherliteCT1
Postby wyldesyde007 » Sun Jun 24, 2018 6:59 pm
And lastly a few shots with the beds made and some last minute items before we pulled off the driveway.
155012155010155011
wyldesyde007
Images: 131
Postby aggie79 » Mon Jun 25, 2018 12:13 pm
Beautiful work! Have a great time camping.
wyldesyde007 wrote:The slot at the top of the door is for an eventual duct to pass a/c out to the fold out room
Can't wait for the details on the fold out room. A similar thought has been swirling around in my head.
Postby wyldesyde007 » Mon Jun 25, 2018 6:44 pm
featherliteCT1 wrote:Man you work fast! .... beautiful! :applause:
I had to! we went ahead and booked a campsite in advance of me doing the build :frightened:
wyldesyde007
Images: 131
Postby rebar » Tue Jun 26, 2018 5:05 am
aggie79 wrote:Beautiful work! Have a great time camping.
Yeah, I didn't think about air conditioning my tent but very interested..
rebar
Postby wyldesyde007 » Thu Jun 28, 2018 1:06 pm
I'm entering into the design phase for the rear room now. Originally we were just going to fold the ramp down and use it as an elevated deck but you know how things go, as your design develops you begin to see new uses. :thinking:
So instead of just a deck I'm going to try and create a fold out room addition on the gate. :twisted:
wyldesyde007
Images: 131
Postby wyldesyde007 » Thu Jun 28, 2018 1:14 pm
My first inclination is to make the fold out hinged so that it just swings into place but with the lift mechanism cables for the door in the way I'm finding that to be problematic; that and my wife wants to still be able to walk out the back door if the room isn't fully raised and use it like a deck. :(
So shifting gears I am thinking more of a hybrid setup with the roof and end wall being hinged and the side walls constructed as sips that will slide into an H channel to hold them in place. 8)
H channel connecting each panel.
155093
Sliding the sips into place from the rear.
155092
Sips stored for folding.
155091
With the sips stored and only the roof and end wall raised it becomes a covered deck which we could potentially hang screen from and make a screened porch. :R
Folding the room up.
155090
wyldesyde007
Images: 131
Postby hankaye » Thu Jun 28, 2018 8:02 pm
wyldesyde007, Howdy;
:thinking: Interesting concept. Looking forward to seeing how it works for ya.
hank
hankaye
