Another way to skin a cat.
Re: Another way to skin a cat.
Postby Hader » Sun Jul 01, 2018 8:04 pm
Hader
Images: 84
Postby flboy » Sun Jul 01, 2018 8:13 pm
Wow... That is really nice! Well done! I like it! :thumbsup: :thumbsup:
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby Hader » Sun Jul 01, 2018 8:26 pm
flboy wrote:Wow... That is really nice! Well done! I like it! :thumbsup: :thumbsup:
Thank you!
What do you think the limitations or abilities of a 40W solar panel? We found one that was on clearance ($ U.S 77.00 including tax) and bought only 1 :thumbdown:
http://www.canadiantire.ca/en/pdp/colem ... 2043p.html
Hader
Images: 84
Postby flboy » Sun Jul 01, 2018 8:36 pm
Thank you!
What do you think the limitations or abilities of a 40W solar panel? We found one that was on clearance and bought only 1 :thumbdown:
The limitations are in the size as you know. 40W will be good for trickle charging a battery or battery bank while in storage. It will
only provide a little over 3Amps in full sunghlight in the best of conditions, which is something and I could see it as being very useful to maintain your batteries when in storage. If you have a small battery and you want to use it for running a laptop or charging a phone, or running a few LEDS, at night, it may provide enough power for that if charging all day with good sunlight. I wouldn't expect too much from it.. just because of the size.
Don (Flboy)
flboy
Images: 378
Postby Hader » Sun Jul 01, 2018 8:50 pm
flboy wrote:I could see it as being very useful to maintain your batteries when in storage. If you have a small battery and you want to use it for running a laptop or charging a phone, or running a few LEDS, at night, it may provide enough power for that if charging all day with good sunlight. I wouldn't expect too much from it.. just because of the size.
That sounds good to me. Thank you :beer:
Hader
Images: 84
Postby beachguy005 » Mon Jul 02, 2018 5:30 am
That's a lot of components to put up an awning. I used 10' of 3/4 emt fixed to the top of the wall and these fittings. I cut the assembly pieces in 5' lengths for ease of handling and storage and use a 10x10 tarp with ball bungees. Allows me to have the awning out 10x10, 10x5 with a 5' drop for some privacy, or fold it under for a 10x5.
I have the emt on both sides so I can use the awning on either side, or both sides, if I buy more fittings. They're easy and quick to use and the 3/4 emt pieces give it a lot of strength. Only takes a couple of minutes to set up.
https://creativeshelters.com/category/flat-fittings
beachguy005
Postby Hader » Mon Jul 02, 2018 8:03 am
beachguy005 wrote:That's a lot of components to put up an awning.
Are you thinking that the EMT, Tees and PVC pipes being 3 Components? :thinking:
Once the EMT is inserted inside the PVC and the tees are glued it becomes 1 component.
Excluding the tarp and bungees, there's only 9 components (pieces) to handle for easy assembly and storage.
For others benefit, please post a photo of your awning.
Hader
Images: 84
Postby beachguy005 » Mon Jul 02, 2018 10:03 am
[/quote]
Not so much about set up, just seemed like a lot of construction parts. This is my setup. I don't have a picture of it out the full 10 feet, just out 5x10 and down 5' and just out 5' and folded under. I have doors on both sides. The nice thing is that using the parts I have used, you could easily go 10x15, 10x20...out as far as you want.
beachguy005
Postby Hader » Mon Jul 02, 2018 12:56 pm
beachguy005 wrote:Not so much about set up, just seemed like a lot of construction parts.
I think it would be fair to say that your awning and ours are totally different, in form, function and ability.
Hader
Images: 84
Postby beachguy005 » Mon Jul 02, 2018 1:13 pm
My comments aren't based on criticism or competition, only observation. But to correct you...they are both the same in function....they're awnings installed to deflect sun and rain.
I drilled 3 holes to mount 3/4 emt to the trailer....you drilled 12 in yours to do much the same thing...so I'll agree they aren't the same in form. I won't judge on ability.
beachguy005
Postby Hader » Mon Jul 02, 2018 1:20 pm
beachguy005 wrote:My comments aren't based on criticism or competition, only observation.
Same here. :D
Hader
Images: 84
Postby Hader » Fri Jul 06, 2018 3:23 pm
Hader
Images: 84
Postby Hader » Fri Jul 06, 2018 3:33 pm
Hader
Images: 84
Postby McDave » Fri Jul 06, 2018 6:54 pm
Looks like you have a little dampness there. Great test for the awning. Nice work Hawk.
McDave
McDave
Images: 412
Postby Iconfabul8 » Fri Jul 06, 2018 9:46 pm
Looks good, now send some of that rain to Utah. We are about to dry up and blow away here!
Iconfabul8
Images: 14
