Internal lining
Internal lining
Postby k1w1campa » Sat Jul 14, 2018 2:30 am
Just wondering if anyone has ever used cork tiles to line the inside of their TD for insulation purposes
Not everyone drinks from the fountain of knowledge, some only gargle!
k1w1campa
Re: Internal lining
Postby greygoos » Sat Jul 14, 2018 5:52 am
Try this post. Apparently cork was used in the walls for insulation and noise reduction. viewtopic.php?f=18&t=62847
greygoos
Re: Internal lining
Postby bobhenry » Sat Jul 14, 2018 6:03 am
I wrapped blue foam with heavy fabric to make a hull liner style interior wall finish..
Images: 2617
Re: Internal lining
Postby QueticoBill » Sat Jul 14, 2018 9:58 am
I have been researching it as the core in place of foam between plywood skins. Not sure if that is what you had in mind. Thermacork seems to be the supplier for several dealer/distributors.
QB
QueticoBill
Images: 22
Re: Internal lining
Postby friz » Sat Jul 14, 2018 2:24 pm
This is 1/4 blue foam covered in ultrasuede headliner.ImageImage
Sent from my SM-G930V using Tapatalk
The "Sin Bin"
150133
friz
Re: Internal lining
Postby working on it » Sat Jul 14, 2018 2:56 pm
  • Great work on that lining! I might try to emulate your method(s), to both insulate and refine my TTT's crude interior (but, it goes so well with the crude exterior!), and give the interior a bulwark against condensation. I never considered insulation until well past a convenient stage to install it, and my later attempt to use a denim/mylar insulation just didn't work. I may not even need the foam board, but just the foam-backed headliner material may be enough for my needs in Texas.
  • About headliner application methods: I've used headliner-specific glues to install a couple (OEM-resto headliners for two of my old Chevy projects, '66 Chevelle & '69 C-10), but I also used 3M Super-77 on two other headliners (my wife's old '85 Lebaron, and my late/lamented '86 S-10 extended cab). I don't have the three last-mentioned vehicles to see if the headliners are still glued on, but the Chevelle' headliner is still OK, after 23 years). The OEM glue holds well, but is inconvenient to use, so I think I'll use Super-77 if ever I start the next headliner project. It was also my choice for use at my job, for many years, for applying identifying labels/barcodes on letter-sized paper tags to attach to plastic wrapping on palletized newspaper products. We used up cases of the stuff, even using a bare spritz of it. The tags would hold fast, even for months, when I had to store the pallets in un-climatized areas of my warehouse. I trust it, very much, though I just recently got a spray can of Gorilla Spray Adhesive, which I want to try on an outdoor project. It's cheaper than Super-77, so I don't expect as much from it as from my old stand-by, but I'll give it a shot (I'm a real fan of Gorilla tape, and this'll be my first try of their other products).
173193172890148599
working on it
Images: 457
Re: Internal lining
Postby saywhatthat » Tue Jul 17, 2018 9:47 am
Do you have small kids that may pick
Il suffit de le faire
viewtopic.php?f=50&t=73945
saywhatthat
Images: 135
Re: Internal lining
Postby friz » Tue Jul 17, 2018 5:58 pm
Both of my kids are in collage.
The "Sin Bin"
150133
friz
