lacofdfireman wrote:Maybe I’m wrong but it seems like it would be so much more money to make a skeleton frame then sheet it both sides when you could just do a 1/2” wall and be done. Sure it’s lighter to make a skeleton frame but if your side profile is 4x8 you’d end up having to buy a sheet of 1/2” to make your skeleton frame then 2 more sheets to skin it where you could have just bought 1 sheet of 1/2” and been done?
Ottsville wrote:lacofdfireman wrote:Maybe I’m wrong but it seems like it would be so much more money to make a skeleton frame then sheet it both sides when you could just do a 1/2” wall and be done. Sure it’s lighter to make a skeleton frame but if your side profile is 4x8 you’d end up having to buy a sheet of 1/2” to make your skeleton frame then 2 more sheets to skin it where you could have just bought 1 sheet of 1/2” and been done?
You don't have to use a sheet of plywood for the skeleton, you could use boards, or even cut your "boards" out of ply. Are you insulating this build? Will this build need to support a RTT like your first one?
