OP827 wrote:This is how folding walls are made with vertical offset to lay flat on top of each other (courtesy of Valentin, build thread here - http://www.caravaning.in.ua/forum/viewtopic.php?f=36&t=1017):
OP827 wrote:build thread here - http://www.caravaning.in.ua/forum/viewtopic.php?f=36&t=1017):
OP827 wrote:My thoughts: rectangular side walls and roof that goes over the whole folded down trailer are easier to seal from weather. Like Gobur Caravan for example, but smaller and lighter in your case.
OP827 wrote:BTW, Did you consider back door? It might work good for the trailer structure and loading long pieces...
OP827 wrote:The side walls look higher in front than in the back, can you describe what is your current design and how do you plan to lift the roof and then support it?
Users browsing this forum: Bing [Bot] and 15 guests
