Iconfabul8 wrote:I think this underside thing has some merit! I like the idea of the reclaimed truck cable lift.
All this spare tire talk has me thinkin! I might have to put some thought into mounting the spare
in front of the poop shoot. Might help protect some of the vitals I have hanging all over that side.
Andrew Herrick wrote:Are you worried that you'll lose ground clearance on the approach angle?
Iconfabul8 wrote:Andrew Herrick wrote:Are you worried that you'll lose ground clearance on the approach angle?
I suppose I would want to pull a line from the bottom of the collapsed front jack and the bottom of the waist valves. Then make sure the tire was mounted only slightly lower than the line. Better to scrub on the tire than to tear out the sewer system. Man would that be a mess if it was full. I guess if you wanted to get fancy you could mount the tire on a hub and let it roll!
P.S. If you ever get around Ahern rentals (400 N. 800 W.), stop and say hi. I am right next door to the east.
there is some wisdom in that, that I had never given any thought to before. We have a lot to tight canyon roads up here and pulling off to the side most of the time I sent even an option.hankaye wrote:Icon, Howdy;
Just something to consider.
I had an experience with a flat tire on an Interstate in Illinois once, There was a section of guard railing
where I came to a safe stop after a driver's side tire literally blew apart. Well, I ended up with about 12"
of space to work before parts of me were hangin' over the white line. That was the leading cause for me
to jack up the trailer with me under it as no one was giving me any room nor were any folks moving over
either.
All the above is why I'll never mount anything related to a tire change to the driver's side of a vehicle
including the door needed to access the tools.
hank
friz wrote:Here is my solution. A couple of carriage bolts through the floor along with big washers and nyloc nuts. Not as handy as some but at least I have it with me.
Sent from my SM-G930V using Tapatalk
