Postal_Dave wrote:I liked the guy's design, but noticed that he already had the corner posts taken out before he started to fold it up. You can see the light in the corners.
One of my first designs, before I built my first camper was kind of like that. But it didn't match my "This is what I want" List
The "This is what I want" List includes:
A Galley
Being able to stand up
A place to put a port-a-potty.
AC
Storage space
Hard Walls
YET.... be compact enough that I can see out my rear view mirror when I tow it.
The Pocket knife had all that but was heavy. The new version should have all that and not have the corner posts and be removable from my trailer. So two new things added to the list.
Dave
“I just hope that when It's set up at the beach, or somewhere like that, it isn't so light that it gets blown over.”
Postal_Dave wrote:Just an update on my experiments with attaching the canvas to the foam.
I used a 2 foot by 2 foot by 1 inch piece of the pink stuff and a small canvas drop cloth from Harbor Freight. I washed and dried the drop cloth so it wouldn't shrink any more then cut it into strips of about 5" x 7". I used a rolling pin, with wood staples that only went halfway in the roller, to put small holes in the skin of the foam then I sanded the foam. I tried using the TBII 50/50 mixture and straight TBII to glue the canvas to the foam. The best result for attaching the canvas to the foam was taking the TBII at full strength and covering the foam with that and scraping it so that the glue filled the holes and the sanded places then letting that dry a couple of days. Then putting down a liberal coat of TBII on the pre-glued surface and then putting the canvas on top of that. I made sure the canvas had the glue going well into it. When I pulled the canvas off the foam, a week later, it pulled off a lot of the foam off with it.
I did the same experiment with the TBII 50/50 and it pealed of easily and it didn't take any foam with it.
I did between 8 - 9 different experiments using straight TBII vs TBII 50/50. Some times the 50/50 took 3 - 4 days to dry and even after a week, it just didn't hold well to the foam. However, I did find that after the initial attachment of the canvas using straight TB, TBII 50/50 was a great way to saturate the pores of the canvas, and the TBII 50/50 didn't seem to cause any swelling of the canvas that could make it wrinkle.
I haven't done any experiments with the gripper yet. I'll let you know what I find out about that.
Dave
