Two coats of paint and a window. I think it looks ok.
Sent from my SM-G950U using Tapatalk
tmclemore wrote:Two coats of paint and a window. I think it looks ok.
And now the fun begins.Olddog1 wrote:just finished stripping down a 2000 Coleman Fleetwood and found the frame this week. Thanks for all the info you've shared.
tmclemore wrote:Olddog1 wrote:just finished stripping down a 2000 Coleman Fleetwood and found the frame this week. Thanks for all the info you've shared.
Whatever you do don't "obliterate" the VIN on the side of the frame. I made that mistake and am now having a hell of a time getting the trailer registered. The state of Texas doesn't like VIN obliteraters.
Thanks Ill send you an email tomorrow with all the details. Looks like I will have to get a court order to reassign the VIN. Its a hard lesson to learn. Its important to know the pedigree of your trailer before making improvements. It used to be much easier to get a registration in Texas. I remember when it was a 5 minute process. I guess the trailer thieves put a stop to that. I guess its better in the long run. Just frustrating.ojgrsoi wrote:tmclemore wrote:Olddog1 wrote:just finished stripping down a 2000 Coleman Fleetwood and found the frame this week. Thanks for all the info you've shared.
So true. I retired from the TxDMV. Email me and maybe I can help you. Sometimes there are options that you can pursue.
[email protected]
2bits wrote:I am an expert in bonded titles but yes with no VIN it is a no go on that. You were saying it used to be easy to get registration in Texas but it sounds like something changed.. So you can't go in and register a new lightweight home built utility trailer any more?
That is a problem. I have a lip inside the door frame to put a rubber seal on. It works so far but i have not been driving in a hard rain. My other thought is to put an aluminum trim piece on the outside of the door with a seal also. I'm not sure what other type of hinge would work. Do you have any ideas that may work to seal the door better?2bits wrote:I saw that you were using what looked like home style door hinges, what do you have planed to deal with water getting in?
tmclemore wrote:Nope. You have to haul it to an inspection station to ensure it is not a stolen trailer and it is in fact home made. The problem I ran into is even though mine is 95% home made the original frame is not. So I can't register it as home made. There are steps to registering it but it involves getting a court order and spending time and money to accomplish the task. Instead I have chosen to build a frame with updated springs and axles. I can then set my home built camper body onto my home built frame go get it inspected and apply for a title and registration. It will take a little time but the cost is about the same and I will have a trailer frame that is not 35 years old. My wife tells me I do things the hard way. I'm beginning to believe her.2bits wrote:I am an expert in bonded titles but yes with no VIN it is a no go on that. You were saying it used to be easy to get registration in Texas but it sounds like something changed.. So you can't go in and register a new lightweight home built utility trailer any more?
Users browsing this forum: Bing [Bot] and 10 guests
