tony.latham wrote:Did you cut your door with a router and template?
T
mattsokj wrote:tony.latham wrote:Did you cut your door with a router and template?
T
I cut out the door from my wall template intending to use if for the door template, however I made it with rounded corners. I decided that bending aluminum trim around the tight radius of the door corners would be a challenge. Since the door template was already cut with rounded corners I couldn't use that. So instead, I squared up the corners in the door cut-out hole in the wall template and used that for my template to cut the doors. I used a 1/4" upcut bit and a guide bushing. The 1/4" gap should leave room for the trim.
I more or less used the technique from Scott's Workshop youtube channel. https://www.youtube.com/channel/UCnaVmH79XWMSWVyaRsXLxng
willrothfuss wrote:Very nice so far!! I am contemplating a build so it is great to follow one in progress. I love the Vestibule, too, but it is way out of my price range.
A couple of questions. The trailer is the one thing that scares me. You said you used the NT Ironton, and changed the axle? What did you use? Is it a torsion axle? Did you move the axle? Also you said you extended the tongue. Any welding involved? What size wheels will you go with?
Look forward to your future posts!
Will
willrothfuss wrote:Sounds good. Since the axle is bolted on as well, I guess that is no big deal to move. I don't have a trailer hitch yet- that would be my first thing. To be honest, I'm not sure how I would control brakes using my 2014 Subaru Forester as a tow vehicle. Researching it, iIt looks complicated. What is your braking set up?
I may stick to a trailer well under 1000 lbs and skip the brakes.
Also, is there anything you have to do to switch to the larger wheels? Would the axle that comes with the Ironton support larger wheels? You can see I m a mechanical idiot. Sorry for all the questions. If anyone else wants to jump in that's fine. I see I have to do more trailer research.
Will
redbicycle wrote:Excellent build. I enjoyed your build log. Where did you buy your door hinges?
KTM_Guy wrote:Get out before its to cold??? You have the Propex!! And I'll say I'm jealous.
We need a full review on the Propex after your first trip.
Beautiful teardrop by the way.
Todd
