rustytoolss wrote:I need to build up a few areas on my TTT. I used XPS foam on my build. Covered the foam with HF canvas/and TBII. Then put 2 coats of TBII as an overcoat But I need to build up some spots.
Will bondo be a problem if applied onto the outer canvas/ or should I use something else. ?
John61CT wrote:Yet another data point for sticking to Glidden Gripper over TB2?
Tigris99 wrote:bonds also will not deal with the flex of foam, will crack and fall off in short order.
Need to explain what you need to build up and why. Things like damage to foam itself is best fixed before applying canvas.
I cant fi d it at the moment but there is a mixture that is good for filling the weave on canvas builds (something canoe builders have come up with) which may be perfect for your situation. Will take time on Google to find it though.
Sent from my SM-G950U using Tapatalk
