GPW wrote:… and then you could even work out some slots and tabs for “interlocking” assembly ...
They have only conceived of using it to protect against surface wear, not trying to hold together boxes made from large foam sheets joined at 90° hurtling at highway speed without any other structural support.linuxmanxxx wrote:I was just looking at the FAQ and it says to add fabric only if you are covering bead foam or paper.
John61CT wrote:I'd be surprised if there's much **tensile** strength at all in any thin coating by itself.
Even the strongest epoxy needs the fabric matrix for that.
Resisting puncture, protecting the friable foam from wear & tear, sure, but not tensile.
Not to mention holding large panels' glued edge-corners together under 100s lbs of stresses without any other framing.
