Padilen wrote:First ride other than my short test ride. Tried going down some seasonal roads. Recent storms caused numerous limbs down. Made my way past those...
Padilen wrote:Turned up the heat in pole barn, got roof cleaned. Im going to let it dry, then wipe it with acetone. And then do a coat of Henrys. With rims only, I gained about 4" more of clearance. So im able to get my head and shoulders over.
I normally have a head ache! But I put a fan up on my top shelf, just for this job. May not get to it today- feeling lazy.hankaye wrote:Padilen, Howdy;Padilen wrote:Turned up the heat in pole barn, got roof cleaned. Im going to let it dry, then wipe it with acetone. And then do a coat of Henrys. With rims only, I gained about 4" more of clearance. So im able to get my head and shoulders over.
Be sure you ventilate well, those fumes can give ya a high that's followed by one nasty headache.
Professional experience, not recreational speaking.
hank
Padilen wrote:I normally have a head ache! But I put a fan up on my top shelf, just for this job. May not get to it today- feeling lazy.
Yes I have heat in my pole barn. I have an outdoor boiler, and its connected to my house and pole barn. But normally it's 48-50 in pole barn. I turned up thermostat yesterday and over night left it at 55. Turned it up to 65° today. Since pole barn is a 10' ceiling lots of heat is trapped above Taz. I've been turning it down, while working !flboy wrote:Padilen wrote:I normally have a head ache! But I put a fan up on my top shelf, just for this job. May not get to it today- feeling lazy.
Is your barn heated? I believe there are some temp ranges you need to mind for the application. You may already know that.... just throwing it out..
The white roof has made a noticeable difference on my rig this summer... worthwhile in my opinion. It looks nice too.
You never said how your new 2 stroke is doing. Were you able to get it all tweaked in and get some seat time on it before the cold weather?
Why do you think a third coat is needed? Did it not cover well and you see voids? Just curious.Padilen wrote:Second coat is on and went much better! But 3rd is going to be needed.
Its not easy to paint horizontal. So first coat was way to thin and lots of voids. In hindsight I should have painted the first coat, the way I cleaned the roof. Laying down on it. It calls for 2 thick coats. First coat was like soaping windows.flboy wrote:Why do you think a third coat is needed? Did it not cover well and you see voids? Just curious.Padilen wrote:Second coat is on and went much better! But 3rd is going to be needed.
Padilen wrote:Its not easy to paint horizontal. So first coat was way to thin and lots of voids. In hindsight I should have painted the first coat, the way I cleaned the roof. Laying down on it. It calls for 2 thick coats. First coat was like soaping windows.
Users browsing this forum: Bing [Bot] and 5 guests
