JokerOne wrote:Does anybody regret getting a 6x14 and wished they had gotten something smaller to tow?
My goal is
For National Forest Roads, and BLM land. (Tow vehicle is a unlifted Jeep JKU with tow package, axle, 3,500#)
Nothing technical, if you can get there in a mini-van, then thats what I'm after.
thanks in advance.
Andrew Herrick wrote:If you want to go places you sometimes can't go in a minivan, then a combined length of 30-35 feet is the magic number. See the blurb below:
https://camperreport.com/best-rv-length ... nal-parks/
Unless you're concerned about approach/departure angles, I think the combined length is the more important number rather than the exact length of the trailer. I only tow 10- and 12-footers around cross country, so no personal data on 14+ feet ...
Iconfabul8 wrote:Any pics of that rig on level ground? Cuz it sure looks like he could easily turn his receiver ball mount over.
hankaye wrote:JokerOne, Howdy;
First off, WELCOME!!!
I pull a 6 X 14 into the Gila Wilderness on the FS roads, I use a 2004 F-250 SD 4X4.
so far no problems. Here's a link to my build pages, should show what I've dealt with.
SHould bring ya to pg. 6.
viewtopic.php?f=42&t=53787&start=75
hank
JokerOne wrote:hankaye wrote:JokerOne, Howdy;
hank
thanks!
That Gila National Forest looks great. Looks like the rangers do a great job keeping the roads graded, and warning signs posted.
Only national Forest roads if been on is in Missouri. My GPS keep trying to get me killed..
Those roads look way better than I what I'm use to. I'm sure their much worse out there though.
Call me a wuss, but I look at it like this. If I have to use 4WD, I've done something wrong. (Like listen to my GPS.. )
As a former Missourian, on behalf of all the rednecks: I apologize. Doesn't make up for all the 8-inch boulders strewn over the limestone and dirt, but it's all I got
JokerOne wrote:dirtsailor2003 wrote:Most of the BLM and forest service roads I travel are tight for the 6x10 behind my 2005 RAV4. I wouldn’t want anything bigger.
thanks, that type of feedback is exactly what I didn't want to hear.. But I needed to hear..
I really appreciate it.
So you mean 6x10 is as wide as you would want, or as long as you would want or both?
thanks again!
dirtsailor2003 wrote:Definitely not any wider. And on lots of roads not any longer. Lots of narrow turns in between trees, rocks, etc. and I should mention I’m not doing any real off-road with this, at least not what I’d like to be doing.
I will say a 6x10 is a good size that I think a lot of people pass up on. Lot of bang for the buck!
