Richrad wrote:I found a “camp water heater” (one of those tankless jobs you hang on a fence) that has a 3 1/2” round exhaust above the burner. My problem is how to make a chimney for it. All RV gas appliances vent directly out the side, and residential (house) vents are too lightweight. If necessary, I can pull a cap off the top before every shower. Chimney needs to go through trailer body which is 1/4” thick plywood. Thanks for any ideas and material sources! PS: I have CO/Propane/smoke detectors and a current will.
