Graniterich wrote:Do you know about kreg screw? Those and glue is very strong.
Sent from my A1-840FHD using Tapatalk
Esteban wrote:You can buy Silkafles from Amazon, Home Depot and many other places. I second the suggestion to a 1/4" narrow crown stapler to attach thin plywood to a wood frame work while adhesives or glues setup. You can leave the staples in after the glue dries. You can buy one from Amazon, Home Depot, Harbor Freight or many other suppliers.
...do people use galvanised staples, or should I be searching out stainless steel...
MickinOz wrote:Thanks mate.
I rate Hitachi tools fairly high.
The next question - do people use galvanised staples, or should I be searching out stainless steel. My head says stainless steel, my wallet says galv.
