Thought experiment, please link to relevant previous discussions, or images / web pages to inspire brainstorming.
Flexible but strong structural framework, maybe temporary if no heavy roof / rack loading.
Curve / shoulder shapes and dimensions optimize balance between slipstreaming vs standing / storage space.
Maybe screening fabric for added strength, aluminum vs plastic?
And/or traditional dropcloth / canvas.
Not flat boards with 90° corners for foam though, the fabric gets stretched over the "sapling" framing, maybe bracing / twine tensioned to get everything nice and rigid, then spray or paint the Glidden Gripper (or what?) to "freeze" the shape
Coat, dry, further coats, maybe measure to get PMF shell to a given standard thickness.
Obviously a manufactured smooth rigid "mold" for commercial production, but I'm thinking hand made artisanal primitive roughness is part of the charm.
Once done, 100% dry and judged "strong enough" on its own
**spray** two-part urethane foam to the inside, again optimizing balancing lost space vs need for extra strength or insulation for a ski-bum scenario.
Even coverage a big challenge here.
Maybe an inside vs outer skin, gap in between then use two-part **poured** urethane foam. Denser at the bottom, lighter at the top?
Plastic pipe used for the sapling framing between skins, fill with dense foam, very rigid shape before skinning, no thermal bridging, likely load bearing enough for panels up top.
Semi-flex panels fit to the curve but mounted rigid, very light?
Entry / windows could be framed in, likely easier to get openings waterproofed, but maybe just do a unitary sealed shell for strength and shape-integrity, then cut out and frame later.
- Picture_20190213_181149934.jpeg (85.58 KiB) Viewed 4243 times
- Picture_20190213_173728211.jpeg (19.14 KiB) Viewed 4243 times
