4 Flat Connector
Anything electric, AC or DC
4 Flat Connector
Postby greygoos » Wed Apr 24, 2019 8:31 am
Looking for any thoughts on trailer connectors. Anyone have any suggestions on quality 4 flat connectors. Most of the ones that I have seen have cheap pins that snap off easily.
greygoos
Re: 4 Flat Connector
Postby Shadow Catcher » Wed Apr 24, 2019 6:53 pm
Unfortunately it appears to be form follows function. Etrailer appears to have what is available. There are non standard alternatives i.e. Anderson Power Poles.
https://www.etrailer.com/dept-pg-Wiring-sf-Trailer_Connectors-pt-Trailer_End_Connector.aspx
Postby swoody126 » Thu Apr 25, 2019 7:35 am
i have used the infamous 4-prongs for ever w/ simiar results
i keep an extra in my TV's tool kit along w/ waterproof crimp connectors a crimping tool and 3-M tape
down here virtually every auto parts Wally World and farm supply store keeps a supply of them and their co$t will not cause me to miss a meal from the $1 menu @ Mickey Dee's(i frequently find them in sets @ local flea mkts for $1/set)
when wiring a new trailer or replacing the lighting system on an older one i do allow a bit more length(a few inches) at the front for the inevitable plug replacement
the wiring most light systems come w/(if you buy a kit) doesn't lend itself well to using the larger connectors which use a set-screw to secure the actual wire in a hollow socket for each wire
many folks are trending toward LED technology (specially the sealed units for marine use) the wiring requirements are falling into the 18-20 gauge range and that stuff really doesn't play well w/ the heavier plugs
note, both of my TVs have 7/flat prong(farm & RV required) recepticles which require an adapter for my smaller trailers
i suppose if you intend to add a battery charging wire a HD plug will be on your horizon and this thread wont really matter
keep an extra set along w/ connectors & crimper on hand
check the plugs w/ each connection/dissconnection and be prepaired to make repairs when needed
sw
swoody126
Postby greygoos » Thu Apr 25, 2019 8:19 am
I am building a new trailer, and prefer to use a 7 way on my trailer and TV. The problem I have is that the trailer usually gets used more by family than me. Most of them have 4 flat. Thank you for your suggestions, it has sent me in the right direction and I think I will place one of these in the tongue box.
greygoos
Return to Electrical Secrets
