HURRICANE HINGE & GAS STRUT PROBLEM
Re: HURRICANE HINGE & GAS STRUT PROBLEM
Postby DWT77 » Sat Jun 08, 2019 7:58 pm
I ordered the 100 lb gas springs earlier this week.
Got them installed and everything is working correctly today
I decided the gas spring mounts needed some additional strength. I made some blocking out of 3/4" plywood.
I used a counter sink from the outside to secure them to the galley hatch gusset
I did add a few more screws than what I have pictured.
Got everything measured out and mounted. Opens and closes easily. The springs keep the hatch closed and I can feel a breaking point at about waist high when they take over and assist with the lift. Then shutting the hatch doesn't require much force.
Last thing I did was make sure I had plenty of clearance on the inside for my cabinets when the hatch is closed. I put my camera inside and took a picture
Thanks Dan for the help and everyone else who responded!!!!
Hopefully my mistakes help someone else out in the future if they find this thread lol
DWT77
Images: 473
Postby tony.latham » Sat Jun 08, 2019 8:04 pm
Wayne:
I'm happy to see Humpty-Dumpty is back together. :)
How does it feel to open and close compared to the first go-around?
I've gone so far as to take a video with the camera inside. :thumbsup:
T
Postby DWT77 » Sat Jun 08, 2019 8:12 pm
tony.latham wrote:Wayne:
T
Thanks Tony
Pulling down to close the hatch is a lot easier. It doesn't take near as much force to break them to close.
I can really tell the difference in opening. Before there really wasn't a breaking point at the waist. When I opened the hatch the springs kicked right in and opened it up. Also the springs don't open it as forceful. If I were to let go and allow the springs to go by themselves the hatch opens slower
DWT77
Images: 473
Postby tony.latham » Sat Jun 08, 2019 8:13 pm
If I were to let go and allow the springs to go by themselves the hatch opens slower.
Better get back out there in the woods.
T
Postby Tom&Shelly » Sat Jun 08, 2019 9:47 pm
DWT77 wrote:I ordered the 100 lb gas springs earlier this week.
Glad it works well now Wayne. Thank you, this thread has been very interesting and informative!
172912 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2021
Postby danlott » Sun Jun 09, 2019 12:05 pm
I am very happy it worked out for you. I do like your idea for beefing up the hatch attachment point.
Dan
Hoplite Traveler Build thread
danlott
Images: 264
Postby KTM_Guy » Wed Jun 12, 2019 10:55 pm
I put one in just hope I never need it.
Todd
KTM_Guy
Images: 193
Postby paintm4u » Thu Jun 20, 2019 1:52 am
I hope your solution works but I have had a little experience with this also. The top attach points are very close to the hinge point and bulk of the hatch weight is on the end of the hatch, like a lever and that will put a lot of strain on the hinge. I moved my top attach point back closer to the center of the hatch arc. This alleviated the stress on the hinge and attach point.
good luck.
paintm4u
