noseoil wrote:Update after a while away. We now have 13,000 miles of towing & I finally weighed this thing at a friend's business scale. Thinking I should call her "Miss Piggy" at this point, since it's tipping the scales at 1660# empty!
I decided to get a better axle setup with a 3500# rating, springs & 10" drum brakes. I called around & had a friend suggest his place up in Phoenix. For anyone in that area, Deer Valley Trailer is very good. Ask for Dan & let him figure the job for you. The new axle, springs, brakes, break-away switch, welding & installation was $600 out the door. It's a great place to do business with & I can't recommend them enough.
Here's the old setup with 2000# axle & springs, just a bit over an inch of movement from axle to frame, which was cutting things pretty close.
[/url]
Here's the new setup in place. Still need to install the brake controller, but that's about it.
[/url]
dales133 wrote:You didn't get lucky you took your time and nailed it. It's a credit too you man
noseoil wrote:OK, the system is installed & working now! Had to run an extra wire from the back area (behind the TV set) up to the tongue box to get a proper signal for the brake controller. The wiring was set up for the 3rd brake light & it seemed better than using a circuit with a turn signal attached to it. PITA, but it's done now.
noseoil wrote: I pull the fuse from the hot line when it's parked (it's using the trailer battery & wiring, not the truck system) then just put the fuse back in when it's ready to tow again. The solar panel keeps everything supplied with power, so it's all good.
Looking at the controller you have, it looks like the same one I have. I keep my one connected to the power all the time as it will shut down after about 15 - 20 minutes of inactivity.
Users browsing this forum: Google [Bot] and 3 guests
