RJ Howell wrote:I wish to say thank you for offering up advise. That's what I was hoping for!
You are quite welcome! Second only to my build, this is my favorite topic.
RJ Howell wrote:To me wattage is wattage. If voltage went up then amperage went down. What I think I'm learning of the DC/DC charger is the alternator is giving far more than is required, well is my case anyway (and seems in yours).
Agree. Typically, your TV alternator is rated at about 100 amps. I don't know how many of those amps are used to keep the TV running.
RJ Howell wrote:I'm not quite convinced a simple $20 solar charger will do it.
I'm not, either, for the same reasons you gave us.
troubleScottie wrote:You might want a fuse just before the DC-DC charger on the feed from the TV. Might be over kill but that is a long length of wire ( TV battery - length of vehicle - tongue - charger ).
Can't hurt, might help. Actually, the input side of the DC-DC charger represents a load, and the trailer-side plug represents the source that the fuse would protect. So a fuse "up front" of the TD would be more better than one in the back. If in doubt, do both. I didn't add any additional fuse other than the one coming off the TV battery.
On the DC-DC charger output side, I reused the original equipment breaker going to the battery.
RJ Howell wrote:I am curious how you wired into your Casita.
From the TV + battery post:
Thru a fuse to a 12v solenoid
from the other side of the solenoid into pin 4 of the 7-pin TV socket, 10 gauge wire or better.
to the TD 7-pin, Pin 4
***Edit*** Inside the Casita I added a junction block from the connector cable to the rest of the trailer. **/edit***
to the DC-DC charger input, 10 gauge or better.
From the DC-DC charger output to the trailer battery thru a circuit breaker. ***NOTE*** This would be a good line to fuse at both ends. YMMV.
NOTES:
Any reference above to "the TD" Also applies to the Casita.
The DC-DC charger is located near the battery as possible.
The solenoid (
https://www.amazon.com/dp/B0064MX7US/?coliid=IXUAR280M3JDX&colid=1FJRWAP74FKDC&psc=1&ref_=lv_ov_lig_dp_it) is activated by any
acceptable to the TV hot-when-running TV circuit, through a fuse (of course) to one side of the solenoid coil and on to TV chassis ground.
Stay away from fuel injector and ignition coil circuits. My Taco didn't like it when I did that. I would suggest a power window supply circuit. ***Edit*** I used one of those circuit taps to do this ***/edit***
The Casita's Power Dynamics thang had the pin 4 wire connected directly to the trailer battery at the factory. You MUST disconnect that wire. The DC-DC charger output is not connected to/thru the PD at all.
