KTM_Guy wrote:For insulation I would check what sizes are available. Where we used to live in the Midwest I could find any size, in PHX all I could find was 1”.
Even at 5’2” I think it would be hard to stand in any kind or drop. A lot of people will have an awning with walls or a tent to change in. I’m 6’2” and can change inside. We mostly disperse camp and can change outside because no one is around.
I went with 1/4” skins on a 1” frame. 1/8” on the inside would be doable. What is your plan for waterproofing the outside? I like an insulated floor but we tend to camp in cooler to cold weather, if you plan to camp where it is warmer 1/2” ply is fine for for the floor. 3/4” is overkill.
You said car for your tow vehicle, what is the tow capacity? That will give you an idea how you need to build.if it’s 2000# you need to be careful building because weight will creep up on you fast. Ask me how I know.
Buying doors is a huge time saver, I have less than 1 hour in my doors total time. But it comes at a high cost. I would say design for a stock prebuilt doors, that you have the option to buy, build or replace if you need to.
Todd
Thank you! I did think of this and haven't found and good ones used around me. Also I guess angle drop (?) Is more accurate of my thoughts.Modstock wrote:Since you are going square. May I refer you to the "cargo trailer conversion" section.
Could be just what your looking for.
Sent from my H1611 using Tapatalk
Thank you! I am just wondering, why did you decide against poor man's fiberglass?printer wrote:"cargo trailer conversion" section
Heck, I didn't consider this option at first but morphed into it, sort of. I will have to check it out. On the cargo trailer idea, I am building mine with a side door and a pair of doors in the back. I have no idea what I will do for camping duties, will work it out as I get more of an idea of my needs. But I am leaving the inside bare, that way I can move stuff if need be. I have a utility trailer and it comes in handy. Having two trailers is not a big burden but if I had the one as a cargo trailer I would have little reason to have the other. When camping slide in a module for shelving, a bed, a cooking module at the back. When in need to move something slide them out and when done back inside. At least that is the concept until I find out if it is worth it to go full camper.
As a good example, by coincidence up in the left top picture of the page as I am typing.
Just unhook the cabinets, remove the wall, access to the inside of the trailer. My back does slope down but I think I should be able to get any piece of furniture or sheet of wood in. Just a thought.
Also I first wanted a poor man's fiberglass trailer but thought about others using it. I am going with 1/8" Baltic Birch, there still is a chance of them damaging it but we will see. On the height you could add a few inches if you decide to slope the front a little if you are concerned with aerodynamics. It was a concern with me. I did an arch but I could have just did a flat panel seeing that the back will not be a traditional teardrop. Going to go check out the cargo trailer section now.
noseoil wrote:Agree about the plywood scantling comments. Normal roof plywood is 1/2" with 2' center rafters (1X2's for floor joists in your case). We used 1/8" for the floor. Since you will likely have a mattress, floor insulation may not be necessary at all. For walls & roof, 1/8" Baltic Birch plywood is a good choice. It's a bit more difficult to work, with 5" X 5' sheets, but seams can fall on interior supports & frames, so it works well on a small trailer. Otherwise, the underlayment grade of 1/4" plywood sold at your local "Home Delay" can be used as well.
Think about finishing the outside (look up poor man's fiberglass on the forum for a cheaper, durable alternative to metal or epoxy), what amount of interior stuff & finish you will need, wiring for the lights, a radio, battery, etc. need to be thought of as well at this point. Light & cheap is good! 2 doors for 2 people is better for sleeping & nocturnal excursions to the outhouse (5 gallon bucket with a plastic bag, potty seat & kitty litter). Good luck on the build, want to see some pictures!
siena wrote:Thank you! I am just wondering, why did you decide against poor man's fiberglass?
I am not talented enough for aluminum skinning.
We will help you!, not as hard as you may thinktony.latham wrote:I am not talented enough for aluminum skinning.
How do you know that? There has never ever been a first-time teardrop builder that skinned their cabin with aluminum that had done it before. There are all sorts of first-time challenges with teardrop building.
There are two things you need to have to build a teardrop. Perseverance and a willingness to learn.
