hankaye wrote:BigDave_185, Howdy;
Had a heater similar to the one in your link in a previous RV. Uses a good amount of propane,
heats like a champ but you need to crack some windows as well as an overhead vent to keep
from co2ing yourselves and the interior from sweating enough to fill your water tank. Mine
was a back-up for emergencies in the winters of Central Utah.
hank
McDave wrote:Hey Dave,
Here is a link for 7 blade wiring. Might be some help.
https://www.ajtnt.com/Info/7-Way-Diagram
Is that insulation foil 2 sides? If not I guess you need to decide if more important to keep heat in or out?
Not too sure about that type of heater, but I use the Wave catalytic safety heater. The catalytic heat does not produce Co2 and there is not really a flame, but it does consume oxygen, so you need to leave a vent cracked to allow fresh air in. My trailer is much smaller, (6 x12) but this does a hell of a job even in Montana. I always end up turning it down to low after a short time. The radiant heat feels like the suns rays heating objects/people rather than air. I have never had any moisture problems and fuel consumption seems pretty low. You might require a larger unit but the 3000btu works well in my case. Here is a link.
https://www.walmart.com/ip/Camco-Olympi ... ected=true
Does it make sense to put the reefer over the heater? I don't see it that way. Unless you have to for space considerations. I have a small Norcold 12/110 volt but its over the sink/ microwave at eye level.
PS latest pics are the right size.
McDave
Edit: here is a PDF for the heater
http://vagabonders-supreme.net/Wave_Cat ... _Guide.pdf
Modstock wrote:Hello from another Utah'n . I'll be watching this build, whatcha think about those LOOK trailers. Any flaws or other things to be concerned about ?
Always wondered what the gaps near the floor are like.
Sent from my H1611 using Tapatalk
BigDave_185 wrote:hankaye wrote:BigDave_185, Howdy;
hank
So sounds like not the best option being it’s not fuel efficient.
Second option or recommendation?
