The Rhode Drop
The Rhode Drop
Postby Gruvin » Fri Feb 14, 2020 1:51 pm
Building my first teardrop. starting with a old popup camper I got for free (I paid too much for it :lol: )
161165
161166
161167
161168
161169
161170
161171
161172
161173
161174
161175
161176
161177
161178
161179
Gruvin
Images: 34
Re: The Rhode Drop
Postby Spotman » Fri Feb 14, 2020 2:32 pm
Looking good.
Sent from my SM-N950U using Tapatalk
2018 Heartland Terry Classic V21
2018 Toyota Tundra DC
Spotman
Images: 241
Re: The Rhode Drop
Postby Cikan Vuz » Fri Feb 14, 2020 5:46 pm
Interesting. I am curious of all the cutouts in the walls.... stained glass windows? Pass-thrus? just windows? Inquisitive minds want to know ;) I thought about putting a leaded stained glass window in one of my walls. After thinking about it, I decided Nay, the road and bouncing would be too much for it, even if I encased it in safety glass.
Cikan Vuz
Images: 11
Re: The Rhode Drop
Postby eLink » Fri Feb 14, 2020 6:14 pm
Cikan Vuz wrote:Interesting. I am curious of all the cutouts in the walls..
Those cutouts are for insulation. Do a search on this site for "Sandwich Wall" for a whole lotta information.
eLink
Images: 142
Re: The Rhode Drop
Postby Gruvin » Fri Feb 14, 2020 6:16 pm
Cikan Vuz wrote:Interesting. I am curious of all the cutouts in the walls.... stained glass windows? Pass-thrus? just windows? Inquisitive minds want to know ;) I thought about putting a leaded stained glass window in one of my walls. After thinking about it, I decided Nay, the road and bouncing would be too much for it, even if I encased it in safety glass.
The cutouts are to "skeletonize" the walls. saves a lot of weight on those 3/4" plywood walls and allows for rigid foam insulation.
The large cutout seen in the front in one of the pictures will be for a window. Window will be 1/4" acrylic and held in with a trimlok gasket. Outer skin will not be cut till after it is coated in epoxy and fiberglass.
Gruvin
Images: 34
Re: The Rhode Drop
Postby Cikan Vuz » Fri Feb 14, 2020 6:47 pm
okay cool. mine are just solid 3/4" plywood... was built that way so was curious. Thank you
Cikan Vuz
Images: 11
Re: The Rhode Drop
Postby Woodstramp » Mon Feb 17, 2020 11:42 am
Really looks good. What did you skin it with?
Woodstramp
Re: The Rhode Drop
Postby Gruvin » Tue Feb 18, 2020 8:42 am
Woodstramp wrote:Really looks good. What did you skin it with?
1/8" Russian (Baltic) Birch
Gruvin
Images: 34
Re: The Rhode Drop
Postby Gruvin » Tue Feb 18, 2020 2:17 pm
Framed out the galley hatch.
161200
Gruvin
Images: 34
Re: The Rhode Drop
Postby Gruvin » Mon Mar 09, 2020 11:26 am
Stained the body. A little blotchy but hopefully when the epoxy is applied it will look good
161286
161285
Gruvin
Images: 34
Re: The Rhode Drop
Postby Gruvin » Wed Aug 19, 2020 6:03 pm
Been a while since I posted an update here. The trailer is dried in finally now for fenders and finishing touches
162982
162983
162984
Gruvin
Images: 34
