Here's a photo.
So basically, the pigtail is too long? I would either move the junction box farther back on the chassis, shorten the cable, or bundle it up under the chassis with several wire-ties.
Here's a photo.
but I guess I could double up on top
tony.latham wrote:but I guess I could double up on top
As you can see in the photo, I did the same to keep all the wires on the bottom. It makes no difference.
Thanks again!
tony.latham wrote:Thanks again!
Another Idaho, "you betcha."
If you haven't already, I'd appreciate a quick and honest review of the book on Amazon...
Thanks,
Yes I did that shortly after purchase. Nice job on the book. Very nicely produced.
tony.latham wrote:I'm sorry this is where text gets challenging. So the 7 pin connector will charge the trailer battery by using the AUX wire to positive terminal on trailer battery and the charger might be used for say, solar? My understanding is that this arrangement would keep the trailer battery topped off while driving. Then, I suppose I could use a Genius charger to charge battery from solar, if NOT driving?
Well... yes and no. Your tow vehicle will charge the battery while towi ng. But the Noco Genius is used when you have access to 120V.
For solar, you need a solar controller (plus the panel of course). Mine's a Renogy Adventurer but there are lots on the market.
...what does that rocker switch do?
tony.latham wrote:Can you recommend a multimeter or source and also wondering how that gets wired in to the overall setup? Does it just run to the fuse box or does it need direct connect to battery?
Doc:
I used this meter:
https://www.amazon.com/gp/product/B013PKYILS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
It has to be wired with the main negative wire run through the included shunt. I did it as in this bottom diagram:
I like the meter but you should also look at this one: (Thanks to Bill Osborn)
https://www.amazon.com/dp/B07CTKYFTG/?coliid=I301972QUD0GSE&colid=3DIEP78B3UWPM&psc=0&ref_=lv_ov_lig_dp_it
I do hope my book helps. If you wouldn't mind giving it an honest review on the big A, I'd greatly appreciate it.
Curious - when all installed is the display on all the time?
tony.latham wrote:Curious - when all installed is the display on all the time?
Did you get the one that I used or the one that Bill Osborn came up with?
Both of them will use so little parasitic juice that it would be hard to measure I think. With mine, I can turn off the back-light.
T
