HandiCramper
Re: HandiCramper
Postby twisted lines » Sat Feb 22, 2020 1:09 pm
Today the back looks like this, and its going to be 60* next week :shock:
Rear door.jpg (63.84 KiB) Viewed 3965 times
Racking up; And Rapin foam
twisted lines
Re: HandiCramper
Postby twisted lines » Thu Apr 02, 2020 11:39 am
Well now that I have spent my stimulus check through amazon :shock: Figured I would try the Music and blow the dust out;
Started on my wiring Diagram, After a first attempt at the old 36 V battery's I may need to change this one in the future, but the other two are to be Minkota / portable / Drop Power. Solar charged as well 84 AH total.
Power packs.jpg (116.38 KiB) Viewed 3622 times
twisted lines
Re: HandiCramper
Postby twisted lines » Thu Apr 02, 2020 6:12 pm
Under table power.jpg (46.63 KiB) Viewed 3601 times
Spent all day drilling holes in this box that is not done, At camp it will live under the table close to here,
hope the table doesn't leak :beer:
Batt box.jpg (50.49 KiB) Viewed 3562 times
twisted lines
Re: HandiCramper
Postby twisted lines » Sun Apr 19, 2020 8:58 pm
Found the worst project ever and at a bad time, Shoulder level or higher with the arms! Took me a while to find an answer to part of my problem.
The monkey on a stick and a scrap of stainless from a plumbing job in a brewery held the front radius alone. Many, Many :beer: s
May this piece please stay in place forever :worship:
Monkey on a stick.jpg (30.27 KiB) Viewed 3538 times
twisted lines
Re: HandiCramper
Postby twisted lines » Sun May 10, 2020 6:06 pm
One piece is still hanging in place no can pull
Matching headliners his and her's 61-3/8" at the widest point On a 4 X10 I think I know what one goes over my head :thinking:
Some fine handy Caulk work (Hers again) then a few runs with Clear poly :thumbsup: how long until till dry :lol: Well the caulk was just touchable with latex gloves at three day's and that's when the poly wen't on.
60 plus Headliner.jpg (52.25 KiB) Viewed 3394 times
Front Section.jpg (39.35 KiB) Viewed 3394 times
twisted lines
Re: HandiCramper
Postby twisted lines » Mon May 11, 2020 1:38 pm
One of my personal boats I replaced all of the wooden interior and used the boat occasionally for two summers :D it sure was pretty got lots of complements
Yep refinished it three times Polished Aluminum, Wood and all, Sold it less then five minutes after parking it with a sign on it at work The third time.
No exposed wood If I can help it.
Items used before final top coat
Caulk then Clear Gloss.jpg (71.13 KiB) Viewed 3366 times
twisted lines
Re: HandiCramper
Postby twisted lines » Wed May 13, 2020 5:25 pm
When I was a younger snot nose punk summer out of high school, I had a great job at a custom auto body shop, learned a lot of fun stuff one of them wasen't fiberglass :o
Road with him to the first Chevrolet / GMC Trucking Nationals in Ogden and we came home with a first place trophy RIP; Moral is
Bed was Fiberglass
Did A little test wet 220 in the front lower right corner today an itwasen't long ago :lol:
twisted lines
Re: HandiCramper
Postby twisted lines » Sun Jul 05, 2020 10:26 am
Set up firm by now for sure, but I have a new summer task.
I am helping my widowed sister downsize, She told me next time, she wants to pick one lantern, I can have the rest :shock:
I haven't decided where to put this yet.
barn find.jpg (59.58 KiB) Viewed 3074 times
twisted lines
Re: HandiCramper
Postby twisted lines » Fri Nov 13, 2020 1:36 pm
I did a lot of searching for a chuck box, and am just starting to gather the things I want to put in it.
I have not seen anything done that's removable in any flatbacks or cargo trailers; If you have done it,
have any good ideas or suggestions please chime in.
While I clean up a (lot) in prep to get started again.
Spare tire plan its resting on the bumper bolting through 1.5" tubing with 2" of foam give room for a 1/2" of something then through the inside wall some time in the future after paint :NC
TL
twisted lines
Re: HandiCramper
Postby twisted lines » Wed Mar 03, 2021 12:33 pm
Few day's of sun couldn't take it & ordered paint, but the cold & rains in the forecast again :thinking:
twisted lines
Re: HandiCramper
Postby twisted lines » Wed Mar 03, 2021 5:16 pm
Skim coat of Caulk, because it doesn't stink & I don't have to mix it,
I read 180 grit; I like 80, that's for the poly / paint! First time :shocked:
(Caulking) Never found a great place that made picking one eazy.
So far I like this one but I sure thought that more then ten times :worship:
twisted lines
Re: HandiCramper
Postby twisted lines » Fri Mar 19, 2021 10:47 am
Yesterday was a good day to open the MEK Nice and windy :?
twisted lines
Re: HandiCramper
Postby twisted lines » Fri Mar 19, 2021 11:13 am
220 dry just didn't cut into it but didn't hurt it so next was 80 again, dosent make dust nor stink :thumbsup:
80 again.jpg (47.46 KiB) Viewed 1792 times
twisted lines
Re: HandiCramper
Postby OP827 » Fri Mar 19, 2021 12:37 pm
Are you using caulking as a fairing compound, what kind of caulking is that?
Or I missed something...
OP827
Images: 405
Re: HandiCramper
Postby twisted lines » Sun Mar 21, 2021 3:25 pm
OP827 wrote:Are you using caulking as a fairing compound, what kind of caulking is that?
Poly urethane :EXP
twisted lines
