If anyone anyone is interested in going with a fiberglass foamie build here are my videos about how I built mine.
https://www.youtube.com/playlist?list=P ... e98uv4rsCT
tem3000 wrote:Mystery solved! Thank you.
I definitely plan on having a weight distribution hitch, no question. I'm sure there are different systems out there, but should I leave these on with the idea they'll likely be used by any/most systems?
tem3000 wrote:A few more (tardy) pictures to share. The project is going super slowly (constricted by time, finances, and pandemics) but I managed to put 1/2" aluminum square tubes on the frame, and began putting flat corner braces on each side of them for the walls of the frame. It's all being JB Weld'd for placement, to be followed by brazing.
tem3000 wrote:JazzVinyl, I finally decided on 8' 2". Given what the focus of this board is, I realize this experiment is way way too big and wide. But it's all a crazy experiment, drawn both from other people's experiences here, and my wild imagination that's not informed by that experience! :shock: Hopefully, people here will at least find it amusing. Someone here pointed out that some states include "equipment" in the legally acceptable width so I'll be able to put lights, door handles and such on.
tem3000 wrote:...On a related note, during the demo, I ended up needing to cut the wires to the electric brakes. Given the expected lightness of the foamie, are the electric brakes necessary? That may be a stupid question...
