Thanks, everyone. Started insulating walls with 1" pink. Very, very annoying to squeeze them
in between the brackets. Note to self - make sure next trailer is all tube all over.
There are also annoying screws penetrating from the outside that I have to work around,
primarily at the top and bottom. I also have to break the pieces in half to get them in.
I think this is better than cutting narrower pieces which will need more foam.
Finally found a relatively efficient way to cut - using the big L tool, using it as a guide.
Cutting a few feet with razor and repeat with thin putty knife (need to sharpen it)
then slide down a few feet and repeat. Using a piece of scrap as a knee support.
Later I will go back and insert foam & apply tape.
![Front_left_insul.jpg](./download/file.php?id=27039)
- Front_left_insul.jpg (100.95 KiB) Viewed 2572 times
![Front_right_insul.jpg](./download/file.php?id=27040)
- Front_right_insul.jpg (87.57 KiB) Viewed 2572 times
