John61CT wrote:Units designed to handle bouncing around will last longer
XR-duous wrote:When the compressor would kick on, it would sound restricted then it would shut off. I plugged it Into the garage after I pulled it and it was fine. Put it back in the trailer just to see.....works perfectly. Now I have no idea if I can trust it or not.
flboy wrote:John61CT wrote:Units designed to handle bouncing around will last longer
What makes a unit designed better to handle being bounced around? Just curious.
aggie79 wrote:flboy wrote:John61CT wrote:Units designed to handle bouncing around will last longer
I don't want to get too far off topic, but the stresses of caused by "bouncing around" are minuscule compared to the normal operating stresses of an air conditioner - compressor vibration, thermal cycling, etc.
I have cleaned the coils several times on my travel trailer's Atwood air conditioner. Visually, there is very little difference in construction between that unit and the window unit I used in my teardrop. The RV unit has more sheet metal bracing, and the motor shaft of the blower and fan is a little larger in diameter (probably due to its much greater length), but the coils, refrigerant lines, and wiring are built and packaged the same as a window unit.
Back to the topic: I think Don "hit the nail on the head". Low voltage appears to be the culprit. What gauge wiring did you use to wire the trailer? Are there any other fixtures or appliances running on the same circuit as the A/C unit. How are you providing power to the CT conversion? It is by generator or campground pedestal? If the latter, they are notorious for not providing correct voltage (low voltage).
Karebru wrote:Interesting conversation. I've yet to hit the road... or bumps with my build. One thing I do know... Appliances fail. Seems like you can count on each new one lasting not quite as long as the one it replaces.
I tried to make my $100, built-in window shaker easy to remove and replace. I think that's the best you can do. I'm not even sure it's gonna be big enough.
I thought about using an expensive roof-top unit, but a big part of the fun in DIY is using things in creative and unconventional ways... Build on what other people have done.
Throw away the instruction books. Right?
