a section of 1/4” copper tube/pipe to go through the floor, & rubber grommet for the hole, & flare fittings
After I drilled the hole, I sealed the edges of plywood with epoxy to ensure everything was waterproof.featherliteCT1 wrote:Tony,
What did you mean by "I sealed the hole for the pipe with epoxy and after it was cured, I installed the pipe"?
Thanks
tony.latham wrote:I can’t think of the name of the U. S. distributor but I’d give them a call.
It used to be Westy Ventures and they were always responsive.
featherliteCT1 wrote:Excellent!
