featherliteCT1 wrote:
“If the breaker is installed in dry area, that will work. It is not recommended if it is in a wet area.
Please ask if you have any additional questions.
Best Regards,
Blue Sea Systems Tech Support
featherliteCT1 wrote:Mtndon,
Does it concern you that the Blue Sea circuit breaker terminals are marked bat vs load side, but the Blue Sea tech in effect said that it does not matter which terminal the battery is connected to?
