Getting ready to do a trailtop component woody looking into different Epoxy's .found this a bit interesting . Penetrating epoxy: . Like the part about heating the wood first.
https://www.epoxyworks.com/index.php/pe ... #more-7278
GPW wrote:We’ve been using “ the Mix “ for many years (40+) to waterproof wood … Cheap , effective , really soaks in and protects wood … Tested on doors , fenceposts , sheds … and TRAILERS …
Socal Tom wrote:Last time I checked, plywood was held together with glue. Glue's are dissolved by different solvents, some glues can be dissolved by water, some by petroleum solvents. I would tread carefully.
tony.latham wrote:For sealing wood, I use Raka's thin-set resin with their slow hardener. There is no added solvent and it soaks in nicely to the wood and really plasticizes the surface. I've done this with the teardrops I have sheathed with aluminum. I also seal the galley floors and the bottom of the 'drop.
I think penetrating epoxy probably has a place for repairing rotten wood. Tony
JuneBug wrote:tony.latham wrote:For sealing wood, I use Raka's thin-set resin with their slow hardener. There is no added solvent and it soaks in nicely to the wood and really plasticizes the surface. I've done this with the teardrops I have sheathed with aluminum. I also seal the galley floors and the bottom of the 'drop.
To clarify, the wood in the picture was eventually covered with aluminum after being treated with the resin, or was the treated plywood the final exterior finish?
