laursand's Canvas over Plywood
Re: glue info for foamies
Postby OP827 » Wed May 06, 2015 6:46 pm
GPW wrote:“ that it will actually reduce the strength of TB2 “ .... logical but not quite applicable , only because even thinned TB2 will make a stronger bond than the Foam ... The foam always will fail first , not the glue ... Try wetting the fiberglass cloth with plain water before applying the glue , A common spray bottle will work ...
The structural strength of skin is required in my case of roof upper part not so much adhesion of the foam, since there is no other structural element but the skin. I think I'll need all strength that TB2 can provide in the laminate.
OP827
Images: 405
Re: laursand's Canvas over Plywood
Postby GPW » Mon Jan 18, 2021 10:13 am
Here’s another PMF video over plywood … https://www.youtube.com/watch?v=z7F1pf0c0Kw
and his conclusions … https://www.youtube.com/watch?v=OpJPwl22lCs
PMF wins again !!!! :thumbsup:
And there’s another reason for a drip edge on all sides … :o
Postby rjgimp » Sat Jan 23, 2021 1:24 pm
GPW wrote:Here’s another PMF video over plywood …
:o :cry: :shock:
That was almost painful to watch him destroy all that beautiful artwork! There are great lessons to be learned here though. Water seepage is an important thing to consider. Really the only problem he had was at the very bottom of the walls. A drip edge would have solved that issue entirely. Everything else appeared completely dry.
-Rob
rjgimp
Images: 7
Postby tony.latham » Sat Jan 23, 2021 3:29 pm
and his conclusions..
I watched it and I must be late to his party. Why'd he rip it off?
Postby rjgimp » Sat Jan 23, 2021 11:44 pm
I wasn't sure about that either. I suspect he was cutting into it because he hadn't put in a drip edge and was experiencing some floor softness from water seepage and wanted to do repairs. Removing all of it was extreme but he did say earlier that although he was impressed by the overall effectiveness of PMF he didn't care for the finish.
-Rob
rjgimp
Images: 7
Postby OP827 » Sun Jan 24, 2021 2:12 am
He said in the video comments that he will re-use the trailer for a kayak trailer and then recycle the windows and other hardware to build a bigger camper using PMF, possibly with bedsheets over plywood for a better finished look. Great tip on dripping edge, it is needed to avoid water damage!
OP827
Images: 405
Postby GPW » Sun Jan 24, 2021 4:53 am
When this Foamie movement started , we were all for “ No Rules”…. Free to experiment … But now I really feel that if you live in a Humid area , we really NEED Drip edges !!! :thinking: It wasn’t the storms and deluges that caused my little problems. It was the ever present morning dew !!! :o A simple drip edge eliminates a BIG problem … :thumbsup:
And for those Woodies , Canvas sticks like Crazy to plywood … !!! :applause:
